Breville 800BLXL 2-Speed Blender Logo
Posted on May 30, 2011
How do i remove the bottom power cord holder on my Breville 800BLXL 2-Speed Blender
  • blazingshado May 30, 2011
3 Related Answers
Anonymous
  • 10 Answers
  • Posted on Aug 04, 2009
SOURCE: Blender stops after about 2 seconds on every setting
correct - replacing the cord is suggested and simple.
Anonymous
  • Posted on Dec 29, 2009
SOURCE: breville blender bbl550 stopps after 5 seconds any setting
Mine does this as well... 5 seconds of operation and then OFF.
My guess is this is a fail safe where the blender is turning itself off to avoid overheating and what could potentially cause this overheating is the blender is struggling to turn the blades. What could cause this struggling of turning the blades I am guessing is a lack of oil in the blades rotating parts.
If you hold the circular blade part and turn it, you'll probably find that its hard to turn? Mine is... and I oiled it up a bit and found I got a bit more usage out of it... although only temporarily.
Ideally I need to pull it apart and oil it properly.
Anonymous
  • Posted on Jul 22, 2010
SOURCE: blender will not run. the power button is lite but
There is a 10 Amp thermal fuse (SF129E) that is supposed to create an open circuit when the motor windings exceed 133 C degrees. Although this fuse should close again when the motor cools down it can become perminantly damaged. Locate the fuse by following the black leads from the coltrol board to the motor brushes. It's inside a cloth insulating sheath secured against the windings with a metal strap and two ty-raps. I bypassed the fuse with a wire instead of replacing it. It would probably just blow again sooner or later. p.s. you need a T10 Torx screw driver to disassemble (screws under rubber feet) $3 at ACE hardware.
Top Breville Blenders Experts
john h
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Breville Blender Expert? Answer questions, earn points and help others
