This is for my IBanez Bass Amp swx100. Capacitor C222 burned. What is the value of the capacitor?
SOURCE: Peavey SP 2G has a burnt ceramic capacitor in crossover
Kim,
Your best bet it to contact Peavey they have an excellent website at
http://www.peavey.com/support/
SOURCE: I have a grounding problem
You need to ground the recorder. Use a WYE connector to get access to the barrel of the guitar cable and find a good ground on a three wire cord wall receptacle. You don't say what model recorder you have which would have been helpful to us. We are surrounded by electric and magnetic fields and typically you can pick up 10 volts AC (with no real current) just as an antenna from the building wiring. Many music devices that run on "wall wart" power adapters have this problem. Also keep guitar away from wall warts as they emit strong magnetic fields for those that use conventional transformers.
104M on both of them
what type of capacitor it is? have the same issue the two capacitor C222 and C223 are both burned.
