You will find compatible batteries for model MS-5200 at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
To open the shaver body, remove one screw on the back. Also partially remove the 4 outer screws found on the metal plate under the cutters. Once these 4 screws are removed you can partially remove the top part of the shaver body (the parts with the trimmer on it). Then you will need to gently pry off the rubberized grip on the front of the shaver. This will reveal two more screws. Remove these to seperate the front and back of the shaver and access the batteries.
You will need to remove the wires from the batteries by melting the solder with a soldering iron. Solder in the new batteries and reassemble. Charge for 24 hours before use
