Computers & Internet Logo
Posted on May 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The problem is how do installed lan driver - Computers & Internet
Anonymous
Level 2:
  • Expert 75 Answers
  • Posted on May 16, 2011
Anonymous
Expert
Level 2:
Answers
75
Questions
Helped
21161
Points
238
TO USE http://devid.info site download all driver to use your device id code
very helpfull to download all driver
Problems with Lan Drivers for ECS 945GCT-M/1333 v3.0 Motherboard! Tried installing Lan drivers for Windows XP 32-Bit for this board and its not working or installing properly as I still can not connec
I see what you mean, ECS say's it's a Realtek device. Then Realtek driver site keeps looping the XP links. In any case, I finaly found a good link. Here is the zip link.
ftp://WebUser:r3iZ6vJI@202.134.71.21/cn/nic/Driver_XP_5800_09202012.zip
They are newer than those posted on ECS, and if this does not work you should consider buying a new PCI NIC.
Good Luck
How to install a LAN Card Driver
installing LAN Card driver either u need to installed manual or automtically .
1. automatically each vendor have its own driver for the lan driver card . so once u download the driver applicattion u just double click and follow the steps it will detect the lan card.
2. manualy u have to extract the the driver file and put it in specifict folder then u have to right click on my computer then click on management the click on device manager then right click on the Lan device which will be makrd yes yellow quesiton mark then u have click on update the driver and select browse my computer to install the driver and then give the path o exit extracted folder you will be done.
1helpful
Were do i turn on my wireless connection on my laptop?
INSTALLING THE WIRELESS LAN DEVICE DRIVER
Please follow the procedures below for installing the Mini PCI Adapter driver:
Installing Wireless LAN driver for Windows XP
1. Click the Start button and then click Run. The Run dialog box appears.
2. Click Browse button and specify the directory as "E:\Drivers\Winxp\Wireless LAN\setup.exe"
3. Click "OK" to implement the setup program to install this driver.
4. Click "Next" twice to continue the installation.
INSTALLING THE LAN DEVICE DRIVER
• Wireless LAN Access When LED turns on indicates that the wireless LAN module is activated. When LED lights off, it indicates that the function is disabled
MUST BE A SOFTWARE ACTIVATED SWITCH
2answers
My lan card drivers are not working. I have Intel D101GGC Motherboard. Please help in that problem. As soon as possible..
1st you check the Lan card driver is properly Installed.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Click on the Network Adapter
  • See the Lan Card Driver.if it is not available then Install the Lan Card Driver.
  • You can install driver from this site Lan Card Driver
  • If Lan Card Driver is Install then check It is disable from the network places in the control panel.
4helpful
My dell lan card is not working,i cannot connect to internet.
Either the LAN card is faulty or the LAN driver is not installed and/or not configured properly or the LAN cable is faulty.
Check Device Manager to see if the LAN driver is installed, working and enabled. If not then re-install the LAN card driver.
If the LAN driver won't install or detect the LAN card then it maybe faulty and needs to be replaced.
Try a different LAN cable.
Is all the LEDs on in the modem?
Try rebooting the modem (power it off for 30 secs and power it up again).
1helpful
3answers
Ethernet not work
Check in the Device manager to see if all the devices are enable and working.
The one with a yellow ? against that device requires a driver installation.
Is the LAN device OK?
How do you intend to setup your LAN, is it for Internet access or a home network?
I need more information on your problem, together with error messages.
Acer notebook travelmate4000 wireless and lan drivers not install
what, im confuzed, can you be clearer
you formatted your harddrive and installed the drivers except the wlan and lan drivers?
3helpful
2answers
Unable to install LAN driver.
Hi there. Those drivers aren't the right ones.
Did you go to the laptop brand website and download the correct drivers? Sometimes they have different types of drivers depending on what type of LAN adapter there is on the computer.
Sometimes there are drivers for Broadcom LAN adapters or Intel. If it doesn't work with one, try the other one.
good luck
2helpful
2answers
Cannot get drivers to install
You will find you LAN (BroadcomLAN driver 4.28) or (Broadcom Giga LAN driver 8.27.1) storage (Intel chip set driver) and Wireless (Broadcomm 802.11b+g wireless) or (Intel 802,11b+g Wireless LAN driver 9.0.1.9)  ->drivers from here:
Plz let me know how you go
regards /Teis
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
