Garden Logo
Posted on May 14, 2011
Not sure if that is the model # Murray Quantum XTE 5hp 21" need an owners manual...having LOT's of trouble..
5 Related Answers
Anonymous
  • 867 Answers
  • Posted on Sep 10, 2009
SOURCE: need a repair manual for a Murray riding
if belt keeps popping off, it is stretched and needs to be replaced.plz rate-bozcro
Anonymous
  • 389 Answers
  • Posted on Oct 04, 2009
SOURCE: murray 42'' riding lawnmower owners manual
www.murray.com
Locate the tag with your model and serial number on the tractor. Be sure you get the number EXACT or it won't work.
Go to Murray's website and download it. They usually have parts listings at the back of the Owner's Manual
GM Elec
Bruce Bracey
  • 1000 Answers
  • Posted on Oct 12, 2009
SOURCE: Want to remove mowing deck on Murray 42590A model.
The link below will take you to a downloadable PDF fill the has your owners manual.
Good luck, let me know.
Regards,
http://www.murray.com/manuals/index.cfm?rd=1
CaptJon108
  • 35 Answers
  • Posted on May 09, 2010
SOURCE: i need an owners manual for a murray riding mower.
First off, confirm that the tractor is in Neutral and the deck is not engaged. You also need to be on the seat, and in some cases your foot must be on the brake. Then try it.
If by "jump" you mean essentially connect one end of a jumper cable to the battery power coming to the solenoid, and the other end of the SAME jumper cable to the 6 gauge (+/-) wire on the other side of the solenoid that goes to the starter, and it cranks, this means one of two things.
More than likely it is the solenoid that is bad, but the only way to confirm this is to make certain that when you turn the key, it sends power to the small (18 gauge) wire on the solenoid. This is easy to check with a test light.
If power is goes to the solenoid when the key is turned, but the engine fails to crank then the solenoid is bad.
If no power is there, then the problem has something to do with either the ignition switch or ignition wiring, or more likely it is a failure of one of the safety switches, under the seat, transmission in gear, sometimes if the deck is engaged, or other.
One way to confirm that the problem is with a safety switch or ignition switch and rule out the solenoid would be to jump a wire directly from the positive terminal to the small wire on the solenoid that comes from the ignition. If this causes the engine to crank, then the solenoid is OK.
vincob
vince janis
  • 718 Answers
  • Posted on Aug 13, 2010
SOURCE: NEED MURRAY 46430X8A OWNERS MANUAL
Try this website it has just about everything anyone could need ( www.psep.biz )
Top Garden Experts
ADMIN Andrew
ADMIN Andrew
john h
CJ Rock
CJ Rock
