Computers & Internet Logo
Posted on May 13, 2011
How do I put a password in my router to make it secure
  • Anonymous May 13, 2011
    What brand and model of router are you using?
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on May 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
1293
Points
14
If it is a netgear router, look on the back of it. When you find the .net address, type it in your browser. When and if prompted for a password enter the factory defalt listed on the back of your router. From there it all becomes easy to follow. Good Luck
Router is un-secured - I need instructions for how to secure it
put a password in your device. my entering the control panel of your router. put the IP address of the router in the search area in the internet explorer. then proceed to security. you can now put a password in your router. to secure it.
How do i name my wireless and put a pass word on to secure it?
To access your Linksys router open a web browser and type: 192.168.1.1
Default username: admin
password: admin
then look for Wireless set up: change name
Then look for Wireless security: Choose WPA personal for encryption and secure your router putting a password
I am trying to put my brothers lap top on my wireless, I put in the pin but now it ask for the security password
The security password is the password for the router,If you have forgotton the security password there is a reset button in the back of the router Press and Hold for 10-15 seconds/Then give it 1 minute to reboot. However this will reset the router to default settings so if it is secure it will be unsecure/ Here is a link to show you how to secure the Belkin router. Hope this helps
http://www.ehow.com/how_4829036_secure-belkin-wireless-router.html
I want to put security password my router, but my cd installer was loose how should i do
Security password for WiFi?
Go to your browser and type:
192.168.1.1
Go to wireless security and choose WPA2 and put whatever password you like. save and exit. Done
Hope this helps!
2helpful
Router password
>If you're trying to put password for the Router, then type "http://192.168.0.1" into the address bar, then hit "Enter."
>Use "Admin" as the username and leave the password blank when the login screen appears.
>Please click on Administrator settings and change the User Name and Password.
If you're trying to put a password/secure the Wireless network, then follow the steps:
>In the Router setup page, click on Wireless Settings.
>Under Wireless Security Mode, select Security Mode: WEP/WPA/WPA2.
>Enter the Security Key manually or enter the Phrase to generate the Security key automatically (only in WPA/WPA2) and save the settings.
>Please note the Security Key to connect to the Wireless Networ.
>The Wireless is secured now.
Good Luck!!!!
How to put password to router
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
I don't know how to password secure my belkin
if you go into the menu from the belkin screen using your internet browser it should say what the address is, something like 192.2.222) then you can put a password on the signal that is coming out of the router. this makes the network secure to only those that know the password don't forget that password.
2answers
WRT54G router working fine but need to turn on security.
with the wrt54g you need to open a internet browser and navigate to 192.168.1.1
a security screen will pop up to which the username is "admin" and the password is either "admin or blank, (unless you specified otherwise when running the install.
once in click wireless then security in the sub menu (under the wireless link you just clicked) then fill in the boxes
4answers
I want to secure my wireless router
Put a password on it.Configure your router for WPA personal (WPA-PSK ) encryption
Username and password
hello!
1. are you referring to the router username and password or the wireless security password ?
2. what is the exact model number of your router?
3. where did you get the message to put in the username and password in an unsecure manner?
-- the default router username is admin with no password
-- the wireless security will depends on what security settings that are configured on the router
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
