SOURCE: internet conection
ATM means Asynchronous Transfer Mode. it's a protocol used to transfer data. it could be that when you are running the setp cd, ATM mode is selected. and if the connection provided by your ISP is not on ATM mode, it'll provide the message that it can't find it. you can check the type of conenction you need to use from your ISP or you can provide me who is your ISP and the model of your modem so i can check it out for you.
ciao!
SOURCE: Blue Hat Toy Company ATM - help! No setup instructions!
ok i hit the rest button on the back of the machine and it erased all my memory off of it so i had to reprogram it .If u put 1234 in as a pin # it will open then press balance and hit enter and u can change your pin # there .
SOURCE: How print ATM fonts in canon 2900b printer
When I print transparancie paper than not print smooth reverse matter why?
SOURCE: Visual Basic 6.0 for PC: how can i get the source code of a ATM machine fun...
You Can download your code from
http://www.planet-source-code.com/vb/scripts/ShowCode.asp?txtCodeId=72945&lngWId=1
