KitchenAid Architect KUDS03CT 24 in Builtin Dishwasher Logo
Posted on May 04, 2011
I have a Kitchen Aid Dishwasher model # KUDSO3CTWH3 , after the washer has completed it wash & drying ( Blue light indicating CLEAN is on ), when I open the door the soap dispenser is open but the soap is still there . Whats the problem please. Thanks Jack from Wilmington NC
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Mar 19, 2008
SOURCE: Replacing detergent dispenser on Kitchen Aid Model KUDI24SEAL3 Dishwasher
send me an email at b4829@yahoo.com and ill send inst
Anonymous
  • Posted on Aug 31, 2008
SOURCE: Dry Dishwasher Soap Still in dispenser after wash.
so here it is...
get a screw driver (you may need a "star" head driver as well), get in there and take out all that you can and clean it (it all comes out pretty easily)...you will find a lot of undisolved soap and hard water build up...rinse it, scrape it, vacuum it...just get out as much as you can...keep note of how you took it apart so you can put it back together...then put 1/2 to a whole gallon of vinegar in and run a cycle (hi-temp if you have that option)...if it was like mine most of your sprayers were gummed up and the water just wasn't moving through the machine...
to avoid this problem...use half of what you have been using of your detergent...and only fill the "pre rinse" section if you are doing pots and pans....and then only fill that half way as well.
after that run a few cups of vinegar through on an empty cycle once a month...
whole job (not including the wash cycle) 1.5 hours...
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Oct 19, 2008
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Anonymous
  • 126 Answers
  • Posted on Jan 16, 2009
SOURCE: Whirlpool Gold Quiet Partner IV issue with soap dispenser
I'd check the spray arms it may be there is not enough water or the wataer is not getting where it needs to be to disperse the soap. that is where I'd start.
Anonymous
  • 105 Answers
  • Posted on Apr 17, 2009
SOURCE: I am trying to replace the soap dispenser on my
As I look at the pictoral, it seems there are twelve screws that hold the inner door to the outer door. Youmust remove these and then separate the door parts. Then you will see the screws that hold the dispenser in place from inside the door.
Top KitchenAid Dishwashers Experts
jdthefixer
gerbee gomez
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
