SOURCE: Danby dpac120068 Air Condtioner, where does the
The hose goes into the empty tank or tray inside (if it's the drain hose like a garden hose). When the hot side of the system goes past there it evaporates the condensation dripping into it. If your talking about the big 4 inch hose, that goes out a window to get rid of the heat from the room.
SOURCE: Danby dpac120068 blue light flashing
E04 refers to Overheating. There might be plenty of reasons. You might have seen, if you shut down the ac for few minutes and again start it, It would work for few minutes and the same E04 display is there.
This is tech's job. I am sorry, i am not discouraging you but it requires certain testing that actually what makes ac overheated.
This is dangerous. So, better to call a tech and get it checked!!
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: I need to replace a
The first place to start is with the manufacturer, Danby 800-496-6049. Or take a section of the hose with you and go to your nearest home center and purchase a similar hose (same diameter) and use all the existing fittings that you have, to remount it with the new hose. There are several types available that will work well for this type of application and probably last longer than the original hose did.
Hope this helped you. Please let me know. Thanks.
SOURCE: Relative Humidity reading is always
I will advice you first make sure the humidistat isn't set too high by adjusting it to
the lowest humidity setting and running it again. Next, test the
dehumidifier by placing it in a closed bathroom with a hot shower
running. If you don't see water collecting in the unit after several
minutes, turn the unit off and clean all dehumidifier filters and
coils. If, after adjusting the settings and cleaning the unit, you
still don't see water collecting, you may have a refrigeration issue. In this case, you will need to get a technician to help check because it is beyond what you can do.
