You could do the job properly with a pair of these as a bridge between the two buildings;
http://www.tp-link.com/lk/products/details/?categoryid=4040&model=TL-WA7510N
Or you could buy a pair of these and keep it all inside the buildings;
http://www.tp-link.com/lk/products/details/?categoryid=1247&model=TL-WA830RE
You should always wire the Access Points into the router when possible. If you place the devices in the window of each building where they can see each other then they will work. The trick with WiFi is if you can see the other end then it *will* work. If you can't see it then it will work a bit or not at all.
Why don't you buy a box of CAT5 cable and just run a really long wire? It will work a lot better and cheaper. You could have one AP at the far end so you have WiFi there.
You can use repeaters which you can place midway between you and the WiFi access point.
Take a look at http://reviews.cnet.com/4520-11334_7-6271405-5.html to have an idea of how it works.
With strategically placed repeaters, you can cover very large areas efficiently.
