ASUS M2N68AM Plus Motherboard Logo
Posted on Apr 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is a problem with my pnp devies - ASUS M2N68AM Plus Motherboard
Brian Sullivan
Level 3:
  • ASUS Master 27,725 Answers
  • Posted on Apr 26, 2011
Brian Sullivan
ASUS Master
Level 3:
Answers
27725
Questions
Helped
5776703
Points
79191
If your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
How do i get to the nettrual safety switch in a 1999 pontiac grand prix
Park/Neutral Position Switch Replacement
Removal Procedure
  1. Apply the parking brake.
  2. Block the wheels.
  3. Place the vehicle is the Neutral position.
  4. Remove the throttle body air inlet duct. Refer to Air Cleaner Assembly Replacement in Engine Controls.
  5. Click to Enlarge
  6. Remove the automatic transaxle range selector cable.
  7. Click to Enlarge
  8. Remove the wiring harness connectors.
  9. Remove the automatic transaxle range selector lever. Refer to Automatic Transmission Range Selector Cable Lever Replacement .
  10. Click to Enlarge
  11. Remove the PNP switch mounting bolts.
  12. Remove the PNP switch.
Installation Procedure
Tool RequiredJ 41545 Park/Neutral Switch Alignment Tool
    Click to Enlarge
  1. Verify that the shift shaft in the Neutral position.
  2. ImportantDO NOT ROTATE A NEW PNP SWITCH. A new PNP switch is pinned in the Neutral position. If the bolt holes do not align with the mounting boss on the transaxle, verify that the shaft is in the Neutral position.
    Adjust the PNP switch if the new switch has been rotated and the pin is broken or if using an old PNP switch. Refer to Park/Neutral Position Switch Adjustment .
  3. Align the flats of the shift shaft to the flats in the PNP switch.
  4. Install the PNP switch to the mounting boss.
  5. Caution! Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  6. Install the PNP switch mounting bolts.
  7. Tighten
    Tighten the PNP switch mounting bolts to 25 N·m (18 lb ft).
  8. Install the automatic transaxle range selector lever. Refer to Automatic Transmission Range Selector Cable Lever Replacement .
  9. Click to Enlarge
  10. Install the wiring harness connectors.
  11. Click to Enlarge
  12. Install the automatic transaxle range selector cable.
  13. ImportantVerify that the engine starts only in the Park position or the Neutral position once the PNP switch is installed. Readjust the PNP switch and/or check the shifter and the automatic transaxle range selector lever if the engine starts in any other position. Refer to Park/Neutral Position Switch Adjustment and/or Automatic Transmission Range Selector Lever Cable Adjustment .
  14. Install the throttle body air inlet duct. Refer to Air Cleaner Assembly Replacement in Engine Controls.
  15. Remove the blocks from the wheels.
  16. Disengage the parking brake. Hope this helps, the page was read only so no pictures. Info is for 3.1L engine.
Dany the t.v devies
0000,6868,2828 are the common codes to check. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/Pull up older posts. Check the site in 'Mosaic' view.It will make search easy.
2helpful
How can I resolve P1706 for Nissan Altima? I replaced PNP switch...
There are only 3 possible causes for that code.
1. Open or shorted PNP sensing circuit between the PCM and the ground for the PNP switch.
2. Faulty PNP switch
3. Defective PCM or possible PCM software update
> I searched for possible Technical Service Bulletins (TSBs) that may address this concern or authorize a software update to correct the problem and found none.
> You have already replaced the PNP switch.
> PCM failures are extremely rare.
This leaves us with an open or shorted circuit that needs to be traced. (which, incidently, should have been checked before replacing any parts.)
Please also review this article:
What Else Could Be Wrong?
13helpful
3answers
What romantic word will found from UIDNVHSE
The answer would be HUSN DEVI, meaning Goddess of Beauty in Hindi.
52helpful
4answers
5helpful
2answers
What is the meaning of uidnvhse?
It is a Hindu word once you have unscramble it. The word is "HUSN DEVI"
2helpful
2answers
Creat a romantic words with letters u i d n v h s e?
Welcome to Fixya. The answer to the puzzle is Husn Devi
In Hindi HUSN DEVI means the goddess of beauty.
Thanks for using Fixya
8helpful
I need to install audie devies for aspire a907
I'd need to know the model # located off the rear or bottom of the unit to get the correct driver for it. Or do it yourself by going here: http://www.acersupport.com/desktop/index.html
Top ASUS Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Rommel Balcita
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
