Http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you
download partition magic you will have the option to make rescue to disks to
boot from make these disks then change your first boot device your to floppy
drive this will give you options to partition then partition only the good
sectors of your hard drive and install an operating system to the good
partition
Partition
Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your
computer-preventing conflicts, protecting data, improving efficiency, and
increasing performance. PartitionMagic allows you to create, resize,
merge and convert partitions without destroying data. Award-winning
PartitionMagic Pro from Symantec is a leader in hard-drive partitioning
software. PartitionMagic Pro allows you to create, resize, move, and convert
partitions without destroying your data. You can quickly and easily create
partitions, which can act as file drawers on your hard disks for storing
valuable information such as data files, applications, and operating systems.
Storing information in separate partitions helps you organize and protect your
data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
click start control panel administration tools computer management disk management from there you will see both partitions on your hard drive right click on the partition you dont need or want you might be able to merge or delete it thi may vary depending on your operating system also i have used partition magic 8 it does not use much disc space and is a very handy tool to use if you have computer problems with it using the boot disc you will have the option to make and its a good learning exercise there are plenty of options with it anyway hope this helps
Thanks, i will try that :) I'm still don't really want to download any programs, i don't want to jeopardise my computer settings if you know what i mean. I might end up asking a proper computer technition eventually, but i thought i might be able to do something on my own. Would you say that partition magic 8 is easy to understand for someone who isn't amazing at programs? :)
partition magic will not change any of your computer settings you will have to make changes your self and click apply and it will always ask before making any changes and they can be undone once you have installed it here is another way of checking both partitions
click start click on my computer you will see your hard drive usually C: right click on it select properties you will see both partitions on your hard drive if you select one without any data in it you might be able to delete it or merge with the other partition by right clicking and see what options are available hope this helps
Thank you! But i don't really want to download any programs as i have low space as it is, and more programs won't really help me, could you suggest any other method of solving my problem without downloading anything? Thank you so much for the solution anyways, don't worry if it is not possible :)
