Have a look at link it may helps
http://www.repairsewingmachine.com/
If you getting loops on the bottom of your material, you need to re-thread the top of your machine. I say this because it is very rare when you will have to adjust the bobbin tension. But if you must, looking straight down at the bobbin as a clock- at 6:00 is the bobbin tension adjustment- lefty lucy, righty tighty. Hope this helps.
The shuttle is a half moon- shaped item. In the machine you will see a driver, which is the other half of that- another half moon. Put the shuttle into the driver to form a complete circle. Place the race cover on the race, snap left ear to the right, right ear to the left, insert the bobbin inside bobbin case, insert bobbin case into shuttle, and you should be good to go.
There is no specific pressure- it just cannot be too tight to bog the machine down and it can't be too loose so that the belt slips over the teeth.
I can walk you through the adjustments if you call my tech help line 732-335-8902. Have a thin philips head screwdriver as well as a flathead screwdriver handy when you call.
pls rate the solution if helped.thanks.
U have to go with a professinol repairer
Try this link may help
Http://www.sewusa.com/Sewing_Machine_Repair/Thread_Tension_Settings.htm
see if that helps, if not contact sears or sewusa.com to aquire the manuals for this machine.
i'll still find more specific to your unit..
tnx
Did
you put the bobbin in the right way round? Is the ends of the threads nice and long before
you start sewing
and are you holding them as you start sewing? Some machines have a
slight tendency to 'eat' the thread tails as you start sewing if they
are too short or not held.Using the instructions in the manual,
thoroughly clean the
entire machine, and oil all designated spots.
Clean the thread path, using lint free heavy thread or cord,
especially between the tension disks.
Remove the bobbin, and if possible the bobbin case and use a
soft brush to clean all areas of the case, lubricate if the
manual instructs you to do so, re-insert the bobbin case.
With the presser foot UP, thread the needle path, including
the needle.
Place a properly wound bobbin in the bobbin case, thread the
bobbin path (and once again, have the manual open to the
threading diagram and be sure you are catching the thread
under/over EVERY spring/slot/opening), leaving a 6" tail.
Holding the end of the *needle* thread in your left hand,
and with your right hand manually turn the flywheel (again
be sure you are turning it in the right direction, refer to
your manual) a full turn, until the needle goes down, picks
up the bobbin thread, and brings it up. Place BOTH threads
between the toes and to the rear of the presser foot, being
sure you leave at least 6".
Place your fabric under the presser foot, lower the foot.
Holding the thread tails firmly with your *left* hand,
slowly start to sew.
If none of this works, you may have to take your machine
back to the shop where you bought it for service and
lessons/instructions.
Just click below for the picture guides
and instructions;
eBay Guides - HOW TO FIX YOUR SEWING MACHINE IN 5
EASY STEPS
Fix It Club | Small Appliances | Sewing Machine
Repair
Don't forget to rate;
Regards,
VOTIT
Sewing Machine Maintenance Needle Faces Where?
I Need to Tighten the Tension....
Changing a Needle
Need Help
Basic Questions-
Bobbin Assembly Popped Out!
Do You Think My Machine is Fixable?
How to Change a Broken Needle
Needle Bar Adjustment
Oiling an Elna 3007
Getting the Timing Belt Off?
What Size Needles for My Machine?
How to Oil my Machine?
Where to Oil??
Stitch Length Knob Woes
Can't Seem to Put the Bobbin in Correctly
Timing Belt Tension
Adjustments
Running Very Slow-
Oiling Points on Singer 257
Oiling My Singer Touch & Sew
Singer 457
Featherweight Case Odor
Brother XL2010 Q's
Does My Machine Have More Than One Belt?
Cannot Seem To Adjust the Tension
What to Do About a Gumming Up Needle
How Tighten My Bobbin Tension, Please
Is it Covered Under Warranty?
Proper Threading Instructions?
Just a Foot Pedal?
Simple Threading Instructions for a 1036
Threading a Singer 600
Replacing a Blade on a Johnson Ruffler
Changing the Needle
Lubricating a Singer 1036
Thread Balling Underneath
Warranty Info
Machine Covered in Hardened Oil
Spindle Stuck?
Do Motors Die?
Singer 457
Brother Sewing Machine
Servicing My Machine-
Belt Replacement
Lubricating My Sewing Machine
Any updates of kenmore diagram!
did the solutions from all of us experts solved your problem if not
then let us know the current updates so all the fixya experts can
assist you further.
latest updates of the problem....
i don't need to know how to thread the machine i need to know how to reassemble the "tension complete"
let me rephrase. i have a kenmore sewing machine model number 158.1355080 and i took apart the tension complete. i need to know how to put it back together.
that is the general idea but i need the diagram for a kenmore not a singer
wrong model :(
i already saw this. wrong model
maaaaaaaaahhhhhh no one can help me obviously. i'm just gonna take it to a professional.
none of the links work.... i don't think that that's what i need anyway. where can i find a kenmore diagram???????
please read the exact description of my problem i DON'T need to know how to thread the machine i need to know how to put the tension complete back together!!!!!!!!!!!!
thank you for that helpful comment
THE ROD HOLDING THE TNNSION PARTS TOGETHER
