Braun Activator 8595 Electric Shaver Logo
Posted on Apr 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you replace a battery on a Braun 7680 Shaver?
Supoj Thammaraks
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2014
Supoj Thammaraks
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3055
Points
I replace my Bruan 7680 battery. I place the order for battery from Amazon, cutter& foil from goodmans.net. The following is my procedure 1.Using a small flat screw driver to plier the plastic socket lock (Where the charging located ) 2.Disassemble left and right plastic holder 3.Disassemble plastic cover top and bottom 4.Take out the circuit board where the battery mounted on. Please be careful at this process you could ruin the circuit board while taking the old battery out(I used a soldering and a small wood stick just to take the extra flux away from contact to other on the circuit board).It is not as difficult as I thought. 5.During your install a new battery please make sure that the batter pole does not go the same way(Check direction of a battery before taking it out so you do not put in the wrong direction) 6.Putting them back together. Note #special tool required to take out the circuit board from a mounting?My the battery replacement came with the tool)
Ginko
Level 3:
  • Braun Master 19,396 Answers
  • Posted on Apr 19, 2011
Ginko
Braun Master
Level 3:
Answers
19396
Questions
25
Helped
8264276
Points
55462
Hi.
The batteries are inside the shaver. You need to disassemble it if you want to replace the battery:
Regards.
Ginko
  • Anonymous Mar 28, 2012
    Is there any chance that steps #1 and #2 can also be added to this diagram? I assume that the end cap surrounding the electrical port must be pried off, but wonder if there is another way to accomplish this.
5 Related Answers
Anonymous
  • Posted on Sep 02, 2008
SOURCE: Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
A
Anonymous
  • Posted on Aug 12, 2008
SOURCE: I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
Pry out the blue button. In the oval hole where the button was you will see a thin metallic part (semi-circular shapes on each side); pull it out through the hole and the switch will be functional.
Anonymous
  • 4 Answers
  • Posted on Apr 26, 2009
SOURCE: I have lost my instruction and cleaning
Here are the instructions for a #7680 Shaver. http://www.service.braun.com/line/SH/S5491/S5491_9_NA.pdf
Anonymous
  • 164 Answers
  • Posted on Aug 29, 2009
SOURCE: how to change batteries braun shaver ?
It is suppose to be rechargeable and have a 2 year waranty on it. send it bback and get a new one or just take it apart and use regular batteries.
Cytherian
Gary
  • 126 Answers
  • Posted on Oct 22, 2009
SOURCE: Battery replacement for Braun 8585
If the "reset" described didn't work all that well, as a last resort you can replace the batteries. You have two choices: put in a battery/circuit-board part replacement (drop in), or solder in new batteries. If you've got some soldering experience, I recommend replacing just the batteries. You can buy new NiMH AA 1.2v flat top batteries rather cheaply (less than $4 per cell) and using a soldering iron, take out the old ones and secure the new ones. Look for batteries with at least a 1650mAh rating. Good luck!
Testimonial: "I believe this is a more viable solution. I will try your advice this weekend. Thanks,."
Excessive vibration with Braun razor
Most likely, the oscillator in the drive unit is broken. You will find this part for model 7680 at shaversource.com. See link below for product and helpful disassembly video
http://shaversource.com/shaver-replacement-parts/braun-7000-series-syncro-motor-drive-unit-p-110.html
1helpful
My Braun electric shaver model 7680 has stopped functioning probably due to a dead battery ( I had it for years). A service center is asking in excess of 60 dollars to fix it. Battery and mother board...
If the shaver is completely dead and the charging lights no longer illuminate when plugged in, the circuit board will need changed. If they still illuminate when plugged in, you can just change the batteries.
You will find the batteries and also the circuit board with batteries at shaveroutlet.com. You can order which you require. See links below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
http://shaveroutlet.com/shaver-replacement-parts/braun-syncro-circuit-board-with-batteries-select-models-p-772.html
There is a tip on the battery page for easier installation
shaveroutlet.com has an instructional video that shows you how to disassemble the shaver at the link below. It's the 4th video down
http://shaveroutlet.com/video_tutorials
6helpful
2answers
Where to get and how to replace the shaver switch on 7680?
The switch is part of the outer case and can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-syncro-body-housing-select-models-p-811.html
To replace, you will need to gently pry off the cap that surrounds the cord hle on the bottom. Once removed, the side grips will pull away easily revealing 4 screws on the back. Remove screws to take the bask of case off and then lift out the 'guts'. Reassemble in reverse order
How do you oil the shaver
all you need to do is add a drop of Braun shaver oil to each side of the foil while shaver is running. if you need Braun shaver oil, it can be purchased at shaveroutlet.com
2helpful
I have lost my instruction and cleaning manual for Braun electric shaver #7680 and need to find replacement.
1helpful
Braun Synchro 7680 - "Oil" message
Had the same problem on my shaver too. Bought this product:
http://www.onlineshavers.com/pd_braun_8000_activator_foil_cutter_pack31.cfm
(I know the link says foil cutter, but it takes you to Braun lubricating oil!)
I apply the lubricating oil to the foil etc, then the word "oil" disappears. Then after a while the word "oil" comes back and I apply the oil again and so on, my shaver still performs normally.
Hope this helps.
Top Braun Health & Beauty Experts
Rob Hill
Rob Hill
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
