HP OfficeJet 6110 All-In-One InkJet Printer Logo
Posted on Apr 17, 2011
What does it mean Error code: OXC4EB841A. I was installing my newly bought HP Deskjet 3050 but the error code appeared and none runs. Could you help ? Thuy
5 Related Answers
puas
  • Posted on Mar 11, 2008
SOURCE: HP LASERJET 3050 SCANNER: ERROR (not set up on pc).
Shirley,
If your still looking for a solution, or to those of you who have a similar problem, the following fixed my problem after trying to resolve the issue over the last year!!!!
I also received the "not set up on pc" message and tried re-installing the software numerous times.
Finally resorted to re-installing windows XP (because of this and other software glitches) and re-installed the Laserjet 3050 software again...but could not get the printer to install.
The problem was occuring while the software was asking to "plug in the usb cable", but would not complete the installation. It was not recognizing the device....the solution was to reset the laserjet 3050!!!!
to reset, push the "menu" button, < (left arrow), go to "service", "enter" button, > (right arrow), "Restore Defaults", "enter" button.
This should reset the factory defaults.
After this, I re-installed software, working!!!!!
Puas
Anonymous
  • 449 Answers
  • Posted on Oct 26, 2008
SOURCE: What to do? HP Deskjet F380 Error with Cartridge 21b.
hi!!!
removed the cartridge
and placed it back properly!!!
Joed911
JDTec
  • 4338 Answers
  • Posted on Nov 27, 2008
SOURCE: error code 22.1:10 on HP Designjet T610
HP does not specify what that error means. It says to contact HP Support. If the unit is in warranty, Hp will repair it, free of charge.
HP and Compaq products
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Anonymous
  • 82 Answers
  • Posted on Feb 11, 2009
SOURCE: blinking lights on my hp deskjet 840c printer
There should be some error .So you know how to remove the catridges just remove it n re insert it properly.If there are any paper jams try removing it also.and by the way if you haven't installed the drivers for HP deskjet this problem may arise.So make sure you ahve don this.Also this can be happened if the printer have some hardware problems.So none of this solutions are working its better to consult it with an expert.
puertobori
  • 7733 Answers
  • Posted on Oct 27, 2010
SOURCE: Just Bought a Hp deskjet
Try The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
