LG RUMOR Cellular Phone Logo
Posted on Apr 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i get to my saved drafts so i can send them
Anonymous
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Apr 16, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
61
Questions
0
Helped
15034
Points
217
Press menu button go to Messaging option then TextMessaging then go down using your navigation key there is your Draft option waiting for you. open draft and send message as you want. Hope it will work for you.
Thanks
1helpful
How do I make a draft sms message and save it. How do I then send it to someone?
To make draft messages on your phone..First go to message menu create message..Type message you want,after typing click OK button of yuor phone there are options that says save messages..To access that message ,go to the message menu choose draft or save message,select the message you want to send click OK and select edit then Click OK button of your phone select SEND then choose the number in your phonebook..Hope this helps..
Jun 20, 2011 • Cell Phones
Samsung sgh-g600 is saving to draft how do i stop it saving to draft
You can stop it from saving into draft by un-checking the option for that in the message settings. Also if you do not send the text and just press the Back key, it would automatically save the text in drafts so you may use it in future. I hope this helps.
2helpful
Lotus Notes crashes when sending an attachment
Is this with any size attachment. Try a really small one, just a blank notepad text file or something. Also try and save the message as a draft before sending it. I've found saving it as a draft and then using something else (Notes Traveller or Web Client) to send it has worked for me in the past. Expect this is a slow connection issue.
I wrote the long message and wanted to send it later. Later I could not find my written mesage to send email. I did not find outbox nor Draft symbol in the screen. How should I get my written message back
It should have been auto saved in the drafts folder. If it is not in the drafts folder, It is most likely gone. Outlook uses word as an editor and word will auto save every so often. It will place an .asd file in your temp folder. Your temp folder location will depend on your Windows version. I'm not talking about windows/temp. It is most likely under Documents and Settings\(your user name)\Local Settings\temp. The Local Settings folder is hidden so you must set your settings so that you can view hidden files and folders.
I suggest either making sure you save your message to draft every so often as you write it .. OR a better solution is to use Word. Word will auto save every so often and the document can be recovered.
How auto save works
How to view your Local Settings files/folders
hopefully you can find the saved file there.
I have a saved draft that I want to send . The original email address wasn't recognised.
nannydiz1- If you forward a saved draft and attempt the new email in the To box, you should be able to send from your draft. This is not a problem with your laptop it sounds like and Email question. Correct?
Save as draft
There are several reasons as to why a message might not have been delivered.In such a case the message is not lost...it simply is not sent and then is saved as a draft on your phone .You can choose to send it later.Look for it in Drafts in your message applcation.
HOHOW W DO I PREPARE DRAFT TEXTS AND SEND THEM?
just type them in your inbox and save as draft. when you have to send it across, just use the option of send
Nov 11, 2009 • Cell Phones
When I go to save an email as a draft it says it
Firstly compose your messages and send directly to your draft. before you do that ensure that you are connected to your broadband properly, then send anything you wish to send
Sep 21, 2009 • Yahoo Mail
2helpful
My yahoo wont save a draft or send an email
my yahoo wont save a draft or send an email
Jan 05, 2009 • Yahoo Mail
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
