SOURCE: Coolant temp sensor
it is located where the upper radiator hose enters the thermostat housing
SOURCE: sensor locations
air intake look at snorkel it could be part of mass air flow check intake for eng coolant
SOURCE: on a 2004 volvo s-40 with turbo where is the
Hi!!
Thermostat location in 5 cil. engines, temp sensor is located just right or upper arrow in picture. I've included a picture of temp sensor and installation instruccions.
Never open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. Also, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
Fig. Coolant temperature sensor illustrated
To install:
If helpful, click below, good luck.
SOURCE: I have a 1998 toyota corolla and need to replace
Follow the hose from the bottom of the radiator to the point where in reaches the engine block. That's where the thermostat is located and the Engine Coolant Temperature switch is there too.
SOURCE: I need to find a
i have a fivehorese penta outboread engine is it water cooled or air cooled
