Astar LTV-3201 32 in. LCD Television Logo
Posted on Aug 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code I need a code to program my comcast remote . It seems they do not have this brand tv on their list.
  • vick8029 Aug 05, 2008
    the comcast remote works the tv just fine. I have to ue my tv remote for volume and sound.
Anonymous
Level 3:
  • Master 6,487 Answers
  • Posted on Aug 05, 2008
Anonymous
Master
Level 3:
Answers
6487
Questions
6
Helped
1604144
Points
18452
Try using code 065 to program your comcast remote to work with that television unit..
Hope that helps......
  • Anonymous Aug 05, 2008
    If it ask for a 4 digit code type 1065 or 0065
Anonymous
Level 3:
Brigadier General:
  • Master 3,614 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
3614
Questions
24
Helped
1033831
Points
10054
    what is the device model/maker you want to use the remote..
    thanks
Anonymous
Level 3:
Genius:
  • Master 1,689 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1689
Questions
8
Helped
576224
Points
4681
Apparently they do not have the brand as you mentioned, i have tried looking for one but none so far, it will be best if you will get hold of comcast and possibly, only possible ask for reprograming to make your Astar work.
just click this link for their contact information Comcast
hope that helps.
    here is what i got from Comcast:
    Changing a Volume Lock
    The Comcast Custom 3-Device universal remote control is set at the factory to control the TV volume in all modes. However, you may change the Volume Lock setting to Individual Volume Unlock to unlock a specific device's volume controls for independent operation in its own mode (e.g., Audio Receiver volume controls in the AUX mode). Or, if desired, you can perform Global Volume Unlock so that the volume controls of all devices can be independently operated in their own modes.
    Unlocking Volume Control For A Single Device (Individual Volume Unlock):
    Press a desired mode key where you want volume to be unlocked (e.g., AUX) and controlled within its own mode.
    Press and hold SETUP until the selected mode key blinks twice, then release SETUP.
    Enter 9- 9- 3 and then press VOL- once. The mode key will blink four times confirming unlock.
    If desired, repeat steps I to 3 (of this section) for each device that you want volume to be unlocked.
    Now, after you select a device that has volume unlocked (e.g., AUX), pressing VOL+, VOL-, or MUTE will control the device's volume only in its own mode.
    Unlocking All Volume Controls (Global Volume Unlock):
    Enter 9- 9- 3 and then press VOL+ once. The mode key will blink four times confirming unlock.
    Now, volume controls for all devices can be independently controlled in their own modes.
    Locking Volume Control To TV Mode (Restoring Global Volume lock To The Default Mode):
    Press TV once.
    Press and hold SETUP until the TV key blinks twice, then release SETUP.
    Enter 9 -9 -3 and then press 1V once. The mode key will blink twice confirming global lock.
    Now, when you press VOL+, VOL-, or MUTE the volume of the selected device (e.g. TV) will be controlled regardless of the mode you have selected.
3 Related Answers
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Nov 02, 2009
SOURCE: need codes for remote control access to go with
If you look at the instruction under 'search for your codes' it will tell you how to scan all the code until you find the one that will work. Down load the manual here for your remote:
http://www.comcast.com/corporate/customers/customer_support/remotes.html
SEARCHING FOR YOUR CODE
If your home entertainment device does
not respond to the remote control after
trying all of the codes listed for your
brand, or if your brand is not listed at all,
try searching for your code.
For example, after trying all of the
codes for your TV, you still cannot get
the remote control to operate your TV,
then:
1. Turn on your TV.
2. On the remote control, press TV
once. Then press and hold Setup
release Setup.
3. Enter 9 - 9 - 1. The TV key will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing Power and TV.
Stop when the TV turns off. A
working code has been found.
NOTE: In the search mode, the
remote control will send IR codes
from its library to the selected device,
starting with the most popular code
first.
5. Press Setup once to lock in the
code.The TV key will blink twice.
Anonymous
  • Posted on Dec 08, 2008
SOURCE: can't program cable remote to operate tv.
10030
Anonymous
  • 126 Answers
  • Posted on Dec 03, 2010
SOURCE: I am trying to program
It wont work because its a TV/VCR combo. you can try anyvcr or combo codes there are but it probably wont work. I work for comcast and have seen this happen 1000 times sorry for the bad news
Top Astar Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
