Canon DR 3060 Path-Through Scanner Logo
Posted on Mar 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello Thank for your cooperation with us, but I have a problem after the definition of a canon scanner dr-3060 has not been identified and demonstrated a lack of scsi Did not find it from the CD and thank you Please reply as soon as possible evelen_m@yahoo.com
Paul Kois
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Expert 332 Answers
  • Posted on Apr 01, 2011
Paul Kois
Expert
Level 2:
Legend:
Answers
332
Questions
0
Helped
71838
Points
907
I am very well versed in Canon scanners with many years of experience on them so I hope my advice helps you out. With any canon scanner that uses SCSI only 3 things can go wrong with them. First I would check the SCSI cable so see if the the connecting heads have pulled away from the cable and the tiny wires are exposed. If so one of the wires may be broken. Or possibly a bent pin on the connector. A simple test would be to replace the cable with a good working one. Then try the scanner to see if it will scan.
Second, the SCSI card itself, on boot up while your still in the boot screen you should see something like ADAPTEC SCSI and then some numbers. Or something similar depending on the manufacturer of your SCSI card. That particular scanner uses SCSI II. If you dont see the prompt window on boot up then I would go to item 3 below.
The last thing to try is item 3 and you will need to go into control panel in windows to do that. In control panel I would look device manager and then imaging. Under imaging if you have a yellow question mark your system does not recognize the scanner as being connected to the computer. If you verified that items one and two above are good and functioning correctly then I would disconnect the scanner via the scsi cable from the computer and reload the drivers for the scanner and then rehook up the scsi cable and reboot the computer. Then I would go back to control panel/device manager/imaging to see if the computer now sees the scanner if it does then you are able to scan again. If it does not, and you have confirmed that the SCSI cable and card in the computer are good and working and the drivers are installed correctly. Then it would be safe to say the SCSI port on the scanner is faulty. The scanner will need to be repaired then by a Canon technican.
I hope this helps you out.
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
