SOURCE: I cant change my decimal place Sharp Calculator model EL-531WH
Set up > TAB > then select how many numbers you want after the decimal place.
SOURCE: How can I convert decimal
After you perform the calculations and press the = key, you can hit the ab/c key to toggle between decimal and fraction. Try .75= then you can toggle between 1/4 and .75
SOURCE: how do i do a fraction on my calculator
ok i figure this is like any other calculator, but without a fraction button. A fraction i somthing / something . so instead of the fraction button use the division button.
SOURCE: how do i convert decimal
You just have to hit the second button from the left, third row down. It says "a b/c" on it.
SOURCE: Sharp El 546W converting decimal to fraction
