Computers & Internet Logo
Posted on Mar 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant set security - Zyxel Prestige 630-C DSL Modem (91004263018)
  • Anonymous Mar 24, 2011
    What do you mean by security? Do you want to set a wireless password or internet access password?
Anonymous
Level 3:
  • Master 1,833 Answers
  • Posted on Mar 24, 2011
Anonymous
Master
Level 3:
Answers
1833
Questions
0
Helped
563715
Points
4774
According to you security settings of your modem is difficult for you.
But you don't have say the OS you are using there. It depend on modem and OS. while installing the driver supported your OS select the PPPoa/PPPoE. After installing go to the web explorer and type the link (IP add) of your modem at the address bar and enter in the modem settings. Your modem vendor will provide this IP or see the manual.
Then go to the security settings and set it pasword protected. Enable the NAT (Network Address Translation)with your Private IP address for security. You can follow the manual to set it properly
I have a netgear router tried to re set it 3 times still not securing the network
are you trying to reset the router, or set up wireless security. You need to be a little more specific. if you cant reset, hold the reset button for LONGER then 30 seconds. if you are setting up wireless security, try to make sure that all settings are correct and apply the settings.
I've lost my security key, and I cant find it! Hoe do I connect my laptop tp my cumputer if I cant remebmer it?!
If you have a router, then you need to do a factory reset of it. I would also suggest you upgrade that surfboard to at least a 5100 series or better. The factory reset is somewhere on the back of the "router" not the modem. It is a pinhole that you push with a pen extended. This will take the admin settings and security setting off and reset the admin to factory default. Once you do this you are going to either connect without security settings or determine the factory default admin settings and reset all security again.
Securing wireless network
By setting up WPA2 encryption you are securing your wireless network from unauthorized access.
For details on how to further secure your wireless network, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
2helpful
2answers
Cant connect netgear router wants security key i
Sometimes the security key is on a sticker underneath unit, if not reset router to factory defaults by holding in the reset button at rear with a pencil or something similar.
6helpful
Security code is not 000 so has been changed - cant get through
try 0000, 1122, 1234, or start phone without sim & dial 2945# * # and go in factory setting options
1helpful
Cant find security settings for voyager 210 router
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
1helpful
Cant read my messages as on security the sms is
EVEN YOU RESET THIS IN FACTORY SETTING YOUR PHONE STILL NEED THE CODE..TRY THE CODE OF FACTORY DEFAULT SETTING..IF STILL FAILED YOUR PHONE NEED TO BRING BRING IN THE MOBILE SERVICE CENTER TO REMOVE THE PASSWORD OF YOUR PHONE.
Cant connect with the internet
i had the same problem about a week ago delete all of your connections and reset default settings.
Security code
u might have activated the phone lock code, so go to phone settings and deactivate it, default code for nokia is 1234. if it still does'nt work try restoring factory settings.
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
