Computers & Internet Logo
Colin Christiansen Posted on Mar 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How much memory can a ASUS K501P accomodate? - Computers & Internet
Brian Sullivan
Level 3:
  • Computers & ... Master 27,725 Answers
  • Posted on Mar 19, 2011
Brian Sullivan
Level 3:
Answers
27725
Questions
Helped
5776703
Points
79191
ASUS K50IP vs SONY VAIO Sony Vaio VGN-SZ44GN? Sony: Processor Speed: 1,800 MHz
Hard Drive Capacity: 100 GB
Memory (RAM): 1,000 MB
Chip Type: Intel Core 2 Duo
Primary Drive: DVD+/-RW
Laptop Size: 13 inches
Features: 10/100 LAN Card, Firewire, Modem, USB, Wireless Network Card
ASUS:
Processor Speed: 2,200 MHz
Hard Drive Capacity: 320 GB
Memory (RAM): 2,000 MB
Chip Type: Intel Pentium Core 2 Duo
Primary Drive: Dual Layer DVD
Laptop Size: 15.6 inches
Features: 10/100 LAN Card, Carrying Case, Modem, Operating System, USB, Wireless Network Card
I decided to upgrade the memory from 512 mb to 1 gig. It was working slow but i was ok with it. I was on battery and i thought i would plug in the power so it would charge...and then the screen started to...
you should be able to upgrade the ram to 2G but it must be compatible. I usually choose Kingston Value Ram or Crucial ram after checking their compatibility list.
What can i do to download a music vedio to my memory card?
Good Day,
there are 2 way.
1. use a Card reader
2. use a data cable for your device
Before you copy make sure that the file you need to copy can be accomodated by the space of your Micro SD. After that just simply Copy Paste..
3answers
I need to know how much ram my motherboard will be able to run without burning up? I have an Emachines t1090 w/ Windows XP, 900MHz Intel Celeron Processor, 128MB SDRAM, CD-ROM 48x Max. CD-Drive, 20GB Hard...
The max for your system is 512MB. You have two memory slots and one has a 128MB chip so if you want 512MB, you need two 256MB chips and throw away the 128MB.
At Newegg, a 256MB chip is $42+ shipping of $1. I'd consider getting a new computer instead.
I don't think memory upgrade will tax your system cooling.
Memory upgrade problems
Same here, except that I haven't even been able to get 512MB x 4 to work. Also upgraded BIOS. Did it run OK on 1GB x 2? (Mine does.)
I want to change my motherboard but i need one that is very good for video editing and can accomodate a dual core cpu with a corsair memory.i have a asus graphics card, and a corsair memory which i want to...
Well, you will find that the memory may not be usable in an new motherboard, especially it it is slower type. Fast ram is a necessity.Also, the graphics card may not be usable if the new motherboard does not support the connector. A good source is www.newegg.com A fast motherboard (Gigabyte GA-MA785GM) )will run about $80, you will need LOTS of ram for video editing, 2x4Gb RAM is $70 for 1066mhz speed, and an AMD triple core CPU, Phenom II 2.8Ghz will run about $120.
1helpful
What speed memory can be put in dell 5100c
Yes, the 5100C motherboard can support up to 8GB of RAM. It's factory RAM is DDR2 5300, but it can accomodate DDR2-6400 800MHz as well (according to factory specs).
1helpful
I have a A50 motherboard and would like upgrade the ram memory
Memory with Toshiba chipsets will be better and u can accomodate 2-4 GB memory.
Problem with post!
hi im josh in cebu phils. may i help you? friend if it happens when your pc reboot after few minutes of log to vista. your main problem is the memory or RAM.your memory cannot accomodate the vista software thats why it shut off. you need to upgrade your memory chip inorder to make the vista software run. if still occurs try also to check the position of the processor if it is seated properly.
Which mother board to go with
any that has 2 separate pci-e, last board ive looked at was an asus crossfire board, looked sweet, would accomodate 2 vid cards nicely. went to new egg and was there
SN:16ZPO43282
You can find manual on your board at:
http://support.asus.com/download/download.aspx?modelname=P4T-M&SLanguage=en-us
You probably need to replace your videocard with AGP 4X 1.5V with DVI output.
Good Luck!
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
