LeapFrog Leapster Explorer Learning Experience Logo
Anonymous Posted on Mar 17, 2011
The volume button doesn't work on our leapster explorer. It shows that the volume is at the lowest point, but it will not increase so we can hear it. We tried replacing the batteries and that didn't work. The game works fine but just without volume.
  • 1 more comment
  • Anonymous Feb 11, 2012
    This was a life saver! It worked like a charm! Thanks so much for posting!
  • rachristos
    rachristos Jun 27, 2012
    Thank you s much Joe Maestro and especially for the more detailed explanation of step 6. It worked great and our Explorer has sound again. I am so happy I fixed it myself. Thank you so much!!!
Joe Maestro
Level 2:
Sergeant:
  • Expert 181 Answers
  • Posted on Jul 15, 2011
 Joe Maestro
Expert
Level 2:
Sergeant:
Answers
181
Questions
0
Helped
65585
Points
563
I had same problem, just fixed it by a little hack. The volume up switch is broken.
1. Remove accessory door on bottom. 2. Remove all screws on back. 3. Open back cover.
Looking at the exposed board, there are 2 volume switches (back to back). Directly next the switches are four contacts: the upper 2 are for volume down, the lower 2 are for volume up.
4. Place the battery pack on the board and hold it down. 5. Press the power button to turn on the unit. 6. Use a small wire to jump the volume up contacts multiple times to change the volume to maximum (or desired level). 7. (Optional) Remove the volume buttons and throw away the rubber cushions to prevent the volume from changing. 8. Replace everything back in place.
  • 7 more comments
  • morandeb Aug 16, 2011
    Hi..I am having this same problelm with the leapster explorer's volume button..can you explain more in detail number 6 above. I am having trouble understanding that part.
    Thank you
  • Joe Maestro Aug 16, 2011
    There are two volume buttons: vol up # vol dn. They are momentary switches. The contactor for the vol up button is broken for whatever reason so the two contacts for the circuit remain open at all times. To activate "vol up", you'll have to close the circuit momentarily. To do this, you could use a short wire to jump the two contacts, or you could use a flat screwdriver to close the circuit. The idea is to close the circuit so that the explorer thinks that you'll pressing the vol up button. You'll need to repeat the jumping a few times just as you would press the vol up button. Once you get the desired volume level, you can press the power button to turn it off. The explorer seems to remember your desired volume level even if you remove the battery pack.
  • Anonymous Oct 24, 2011
    This is great if the volume "up" is broken, but the switches are on opposite sides of the circuit board. If the volume "down" is broken, as in my case, the pins on the "down" momentary switch are not visible unless you unscrew the circuit board from the front face as well, then flip it over.
  • Jackson101a Nov 30, 2011
    Just did this and it worked great! Thanks so much for the great info! My daughter will be so happy:)))
    Thank you so much! It worked like a charm!
  • Anonymous May 10, 2012
    I'm really sorry but I really am not getting step 6 - I don't understand or see where the "contacts" are - would there be a image someplace that you could direct me - this is exactly our issue but i am stuck at what to jump. I'm not a very mechanical mom :)
    Thank you!
  • rachristos
    Thank you so much Joe Maestro. Your solution worked perfectly and I am thrilled I fixed my son's explorer myself. Thank you esp for the extra details on step 6 - it took me a little while to get the connection to work, but I managed it. Thank you!!
  • chia517
    chia517 Nov 17, 2012
    Here's a solution that won't require opening up the leapster. Connect the toy via Leapfrog Connect. Click on "Settings" on the upper right-hand corner of the screen. Three tabs will appear: General, Advanced, and Leapster Explorer. Click on "Leapster Explorer." Three more buttons will appear: Reset, Repair, and Check for Updates. Click on the "Repair" button. Leapfrog Connect will bring up the volume to the best level (not the loudest).
  • Anonymous Aug 25, 2013
    chia517's solution worked for me. I think this is a much better option than having to open the machine.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 01, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3055
Points
Anonymous
Level 1:
New Friend:
  • Posted on Jun 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3055
Points
We have the same problem. Did you get it fixed or talk to anyone at leapster?
Top LeapFrog Toys Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
