Refrigerators Logo
Posted on Mar 14, 2011
How to remove casing from kelvinator (leonard) refrigerator to change light bulb, old fridge in good working order
5 Related Answers
Michael Anderson
  • 172 Answers
  • Posted on Oct 28, 2008
SOURCE: light bulb replacement doesn't work
Hi Liz,
The reason they want you to disconnect the power is to prevent shock while installing the new bulb. The door switch controls the light in the freshfood so you really do not need to disconnect power, just be careful not to stick your finger into the socket. In most cases the bulb is hard to get securely screwed into the socket. The moisture in the refrigerator causes defect in the metal around the bulb socket and causes the bulb not to make a secure connectioin. So to repair your problem you can first off make sure the bulb is securely screwed into the socket. If it does not work you can check the voltage at the socket for the 110 volts. You can do this with any volt meter if you have one. Sometime the new bulbs can also be bad, its rare but possible. If you are not getting the proper voltage to the socket then you may need a door switch. If you have another light working in the freshfood then the door swith will not be the problem. The door switch is the only power feed swith to the socket, so one of those two will definately fixYa. Good luck and have a great day.
Mike Anderson
Anderson Appliance
(865)945-3808
Ken Bledsoe
  • 306 Answers
  • Posted on Jan 01, 2009
SOURCE: how to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
alex_salve
ALEX SALVE
  • 78 Answers
  • Posted on May 17, 2009
SOURCE: fridge area is freezing
unplug the refrigerator for atleast 6 hrs , again connect it , should work
Anonymous
  • 53 Answers
  • Posted on Mar 09, 2010
SOURCE: How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Apr 09, 2010
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Top Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
