The waste ink tank/pads for an Epson Stylus DX8450 printer are located at the bottom of the printer's housing, beneath the print head. Here are the steps to access and replace the waste ink tank/pads:
Turn off the printer and unplug it from the power source.
Open the printer cover to access the ink cartridges.
Gently push the print head to the right to move it to the ink cartridge replacement position.
Look for the waste ink tank/pads at the bottom of the printer housing, just beneath the print head. They may be covered by a small plastic panel.
Remove the plastic panel, if present, by gently pulling it toward you.
Use tweezers or gloves to carefully remove the old waste ink tank/pads from the printer.
Replace the old waste ink tank/pads with a new one, making sure they are seated properly.
Replace the plastic panel, if present.
Push the print head back to its original position.
Close the printer cover.
Plug the printer back into the power source and turn it on.
Reset the waste ink counter by following the instructions in your printer manual or by using a reset utility program.
It's important to note that replacing the waste ink tank/pads can be a messy and complicated process, and it may be best to have it done by a qualified technician or Epson service center to avoid damaging your printer or causing a mess.
The Epson Artisan 835 waste pad is located in the printer's waste ink compartment and is designed to absorb any excess ink that is generated during the printing process. Over time, the waste pad can become saturated with ink, which can cause issues with the printer's performance.
To clean or replace the waste pad on an Epson Artisan 835 printer, you will need to follow these steps:
Open the printer's cover and locate the waste ink compartment.
Carefully remove the waste pad from the compartment.
Clean the waste pad with a damp cloth, or replace it with a new one if it is heavily saturated with ink.
Reinstall the waste pad into the waste ink compartment.
Close the printer cover and plug the printer back in.
It's important to note that this process can be messy and you should use gloves and old clothes to avoid getting ink on your hands or clothes. Also, some printer models may have a different process to access the waste pad, you might need to consult the printer's manual or Epson website to know more about your specific model.
Look at this link for the app to reset the waste pad ink counter, and the video helps too; remeber to clean your waste ink pad because it can spill ink to your desk in a extreme case; you need to open your printer to clean the waste ink pad; search for instructions online.
PD: I have reset my counter six times and cleaned the waste ink pad two times; after six years I keep using my printer correctly. http://www.ssclg.com/epsone.shtml http://www.dailymotion.com/video/xgkbji_resetting-protection-counter-on-epson-printer-ssc-service_tech
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. Should you decide to have a go at changing the waste ink pads, the 830 service manual can be downloaded from here:
