Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
Posted on Mar 05, 2011
I am getting the code 32 on my carrier weathermaker 800 furnace. How do I solve the problem
5 Related Answers
A
Anonymous
  • Posted on Nov 25, 2007
SOURCE: carrier furnace weathermaker 8000
I think the running on power up is just a test mode for a service person.
Anonymous
  • 288 Answers
  • Posted on Dec 19, 2007
SOURCE: Carrier weathermaker sx 58 furnace
This sounds like a thermal disc or the heat anticipator on the thermostat is not set right. What was the $500 spent on?
Anonymous
  • 86 Answers
  • Posted on Mar 28, 2008
SOURCE: Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Anonymous
  • 828 Answers
  • Posted on May 22, 2008
Your hot surface igniter may be bad. It may be cracked which would prevent it from starting the burner flame.
wbwill
William Babbitt
  • 68 Answers
  • Posted on Nov 22, 2008
SOURCE: Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Top Carrier Heating & Cooling Experts
Sudeep Chatterjee
Sudeep Chatterjee
jdthefixer
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
