Washing Machines Logo
Posted on Mar 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I got a ue code - LG Washing Machines
Anonymous
Level 2:
New Friend:
  • Expert 70 Answers
  • Posted on Mar 02, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
70
Questions
0
Helped
33804
Points
227
UE means unbalance error. It means the machine can't balance the clothes in the drum so it won't spin to prevent excessive vibration and damage to the machine.
Usually opening the door and rearranging the clothes helps, or take some out then put onto a rinse and spin. If there is just a few items in then it will struggle to spread them around and balance.
2helpful
LG top load washer has a 'UE' Error.
Question edited for clarity
An LG washer displaying the UE or uE error code means that the load in the washer is unbalanced. ... When the uE error code is displayed, it means that the washer is trying to resolve the issue. The washer will fill with water to try to balance the load. It will then drain and try to spin again.
Jun 7, 2021
How to Fix the LG Washer UE Error Code - Fleet Appliance
https://fleetappliance.com > News and Tips
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
UE Error Code
The UE error code (Unbalanced Error) displays when you wash items that cause the machine to shake badly during the spin cycle, if possible wash and drain the items only, then open the door and stack the items evenly on both sides of the drum in order to balance it, now select the spin cycle.
5helpful
I am getting alert of UE for fully automaticatic washing manchine
According to Lg Ue error code is an unbalanced load error code or uneven load error code you can also click this link from the LG site which describes some ways to alleviate the problem of the UE error code http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800. I have also found that if these ways do not remove the problem you may have to open the unit and check the damper struts that attach to the tub assembly. If one of these struts were not to be attached or have broken, or came away from the tub assembly this would also cause the UE error code as well with the unit. Also if you remove the rear panel you will see the stator which is basicly the motor as well as an rps sensor which helps the stator to rotate. I also have found that in some cases the center bolt that holds the stator in place sometimes unloosens and unscrews as well also causing this UE error code. So you would first try the methods that LG has listed in order to alleviate the UE error code and if there methods did not work then you would first look at the stator center screw to assure that it is tightened and in place. And secondly if the stator screw were in proper place and tight then you would look at the damper struts in the unit lastly. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks
Rick
Error code "UE" clothes have
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa !!
2helpful
2answers
LG washer Model # WM1814CW problem code UE
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
WM1814CW Front Load Washer: UE error code on display...
UE is Imbalance error..Redistribute the load or you may have tried to wash something which will not 'spread' enough to balance the load...Nomess
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
33helpful
7answers
Ue error code on the display
For "ue" an unbalanced load is sensed three times, re-adjust your load in the machine.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
Top LG Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
