Electrical Supplies Logo
Anonymous Posted on Mar 01, 2011
We have two circuit breakers, a 70amp double pole and a 50amp double pole. The 70 amp double pole seems to be fused onto the silver bar and unremovable. The 50 amp is removable. The 70 died out on us. Can we just replace the 50 with a 125 and attach the wires from both the 70 and 50? or do we need to replace the whole box? This is the main switch for the whole house. There are 2 other boxes with the individual breakers for fridge, oven, etc. Thank you for your help!
Anonymous
Level 3:
  • Master 843 Answers
  • Posted on Mar 01, 2011
Anonymous
Master
Level 3:
Answers
843
Questions
0
Helped
401001
Points
2420
You probably should not replace a 50 and 75 with a 125. The problem is that although the 125 would have the capacity to supply the same current as the combined 50 and 75, each branch would be provided up to 125 alone, instead of the 50 or 70 that they were allowed before. That is, the 125 won't trip unless both branches exceeded their 50 and 70 amp limits simultaneously. If at any time one branch is drawing very little current, then the other branch would be delivered up to 125 amps. If it is OK that each branch can receive 125 amps alone, then a single 125 would be OK.
And if you have damage to the bus bar, you will have to replace the whole box.
On the other hand, if the existing wires will reach, you might be better off simply replacing all three boxes with one panel.
good luck, be safe Al K
  • Anonymous Mar 01, 2011
    One more consideration---- the output lugs of the 125 must be able to accept two output wires.
  • mysterylect Apr 30, 2011
    The point is, it is highly likely your 50 amp circuit uses wire sized for 50 amps and your 70A circuit is wired for 70A By putting both wires on a 125A breaker, you are exposing either (or both, depending on how you look at it) circuits and therefore the wire to as much as 125A continuous. This is a good recipe for a wiring fire inside the walls.
Top Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you an Electrical Supply Expert? Answer questions, earn points and help others
