Schwinn Meridian Adult 26-Inch 3-Wheel Bike Logo
Posted on Mar 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I too have a clicking in the rear end, it has gotted worce. A scrssching noise now heard. Walking nent to it has not helped, appears to be internal.
nobody
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 28, 2016
nobody
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3543
Points
There are two hexagonal bolts on each axle on the back wheels that are rubbing against the frame of the bike. Take the back tire off (or just loosen the outer bolts and move the wheel away from the bike a bit. Then loosen those two hex bolts so they aren't rubbing on the inner frame. You might need two wrenches, one to hold one of the bolts and the other to turn the 2nd bolt.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 23, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4274
Points
I have been through two Schwinn 26" trikes. A Meridian and a Town & Country. They both have the heavy clicking sound in the rear end.
My Schwinn dealer finally discovered the mysterious problem. Schwinn help line group couldn't find or did not want to admit the problem.
The end of the drive axle's flat side is rounding off as time marches on and thus click click as it wears down. Schwinn repalced one rear axle to fix the problem but alas it also wore down. They wore down within 40 miles usuage. Faulty batch of rear end axles. Hm-m-m-m.
Now I want a replacement Miami Sun trike for my trouble.
Tony Parsons
Level 3:
  • Master 6,407 Answers
  • Posted on Jun 29, 2016
Tony Parsons
Master
Level 3:
Answers
6407
Questions
Helped
1694108
Points
20281
If your rear end is clicking I should see a doctor - it might be something serious.
jwscore
Level 1:
New Friend:
  • Posted on Mar 01, 2011
jwscore
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3694
Points
It could be one of many things,The first Thing I would do is check whereabouts the noise is actually coming from,ie lifting the back of the bike up with a help of a friend and spinning the wheels one at a time and after both wheels being spun rotate the pedals and see if its coming from the gear cog at the rear,Whatever is the problem the part needs to be cleaned out and a new part put back on.It may be just a cracked ball race in one of the wheel spindles.
Top Schwinn Cycling Experts
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
