Washing Machines Logo
Anonymous Posted on Mar 01, 2011
Error code:f16 - Siemens Washing Machines
Anonymous
Level 2:
Sergeant:
  • Expert 196 Answers
  • Posted on Mar 01, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
196
Questions
0
Helped
70843
Points
647
F:16 means the door is not being sensed that it is closed. If the door is deffinately shut then unplug your washer for 60 seconds and see if the control board is just confused. If you plug it back in and still have the same problem then you need to replace your latch assembly because it's not sensing the door correctly.
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
What does error F:16 indicate?
It would be helpful to know tha make and model. Different manufacturers use the same code for different things. Can't tell from the picture (It looks a bit ike a Whirlpool)
Error: F16,
Machine: Washing machines & Washer Dryers,
Type: Standard,
Fault: Water level far too high. Check pressure switch, pressure hose (for blockage or disconection)also the pressure chamber for blockage
Error: F16,
Machine: Dishwasher,
Type: Bosch EXXCEL,
Fault: Door not closed. Check door is closing properly or door switch.
Error: F16,
Machine: Washing Machine,
Type: whirlpool (not every model),
Fault: Faulty control unit.Check wiring connections, replace unit.
Error: F16,
Type: Dyson CR01,
Fault: Motor fault.(Faulty triac).Check motor and associated wiring, check module and connections Faulty tacho. check tacho and associated wiring, chech module for loose or defective connections.
Error: F16,
Machine: Washing machine,
Type: Bosch WFP Series,
Fault: Rinse sensor is fault.(This error code will only show up in test mode).
2helpful
2answers
F16 error code on washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board.
3helpful
8helpful
Error code F16
F16 on a Bosch indicates the door is open / unlocked.
The wash programme should halt when this comes up but you should be able to restart it when the door is closed.
As the cost of a new door interlock isn't overly expensive I would suggest fitting a new lock on a "fit and see what happens" basis.
Whirlpool Duet
your main processing board is having an communitcation error. if you have taking the kickplate off the tech sheets or on the right or let hand wall and will tell you how to enter the diagnostic phases
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
5helpful
Nikon N60 35mm camera error code FEE
Check your lens aperture ring setting. It must be set on the highest number I.E. f16,f22,f32..
Top Siemens Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
vince
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
