Daewoo Lanos 1999 Car Radio/stereo Wire/wiring Harness Logo
Posted on Mar 01, 2011
I have a Lanos Daewoo 2001, my radio is playing the problem i have is with my DVD player, used to play at first, after a week or so it's not. Once my disk was stuck inside. Not playing at all.
5 Related Answers
Hand-sama
  • Posted on Jun 10, 2008
SOURCE: DVD/VCR Locked
My DVD/VCR Daewoo locked and everytime i pressed a button it just said LOCK! I plugged off the vcr for a few hours and then plugged it back in and pressed the on button. Now im watching the dvd that was stuck inside. Try it, you just never know.
Anonymous
  • Posted on Oct 21, 2008
SOURCE: !999 Daewoo Lanos
It verifies well the year, it is of one of 1999
I hope that it should serve you
stevenhurc
Steve Hurc
  • 459 Answers
  • Posted on Jun 21, 2009
SOURCE: 2001 Daewoo Lanos Fault 63.58X 'B'
DTC 63 Will Set When
No voltage is supplied by the ECM through the EST “B” line while reference pulses are received by the ECM from the crankshaft position sensor
check white wire terminal B on ignition coil to ECM terminal C14 for open circuit or short to ground while disconnected if thats ok check for voltage signal at B while cranking no signal ECU faulty. voltage signal also on A terminal while cranking and check earth terminal C to body no higher than 5 Ohms
power is terminal D 12V
if getting power, earths good, and both signal voltages are going into coil pack, coil pack is faulty.
Anonymous
  • Posted on Jul 13, 2009
SOURCE: dvd "unknown disc" message coming up
When Your DVD shows "LOADING" for quite some time and then if shows "UNKNOWN DISC" or "NO DISC", Open the cover of your DVD Player, Remove the flap over the disc by opening the screws. Remember that you are not keeping your eyes perpendicular to the lens. Now take Colin liquid in an ear buds and rub over the lens. Now with dry end of the bud, rinse it and make it dry. Keep the disc in the space provided for. Put on the Flap over the disc. And try to run it. I hope this would work fine.
Anonymous
  • Posted on Jan 21, 2010
SOURCE: Cannot play ipod in 99 daewoo lanos
instead of pressing the left/right scanning buttons hold them and then let go when you want to stop
Top Daewoo Car Audio & Video Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Daewoo Car Audio and Video Expert? Answer questions, earn points and help others
