You can try to run the software in compatibility mode, which means that you can tell Windows 7 to run the software as if it was any previous version of Windows. To do this, browse to the setup.exe or install.exe file on the disk, right-click and select "Properties". Go to the "Compatibility" Tab, tick the box and select a previous version of Windows - the back of the CD Case will tell you which is the best version.
According to it's system requirements, it only will work with Windows 2000, XP, or Vista. However, as Vista is practically the same operating system as 7, it should work ok. Be warned however that not all software that works with Vista also works with 7. You should try looking for a demo version or find someone that has it and borrow it to test it out before you buy it.
