Welcome to FixYa!
Paper
jams can be real or false. The product might report a paper jam even
when there is no jammed paper. The following steps apply to both real
and false paper jams.
Go to this link for the complete steps to clear out a paper jam http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01617494&cc=us&lc=en&dlc=en&product=3752459&tmp_track_link=ot_search
Rates and comments are appreciated.
Thank you for using FixYa.
Jas
SOURCE: paper jam #2
If you moved the heating part ... there is an optical contact in tha back of the printer: a mate plastic into an optical contact, The black plastick should stay between the optocal parts.
SOURCE: major problem please help
i have had that problem for about 3 or 4 months and tonight i went inside and just started cleaning everything and my paper feeds right now. it was really weird. it just started working out of the blue.
SOURCE: The paper will not feed correctly. The Right side is getting jam
First jam a paper on purpose then you will know where the jam is . and you will also know where to find the paper which is under the white cylinder.
SOURCE: Lexmark X4650 ink jet printer has paper jam
Please follow these steps to set your printer to defaults:
1. Please make sure your printer is set in Copy Mode.
2. Press the "setup" button, you will find "Maintenance" displayed.
3. Use your arrow keys to locate "Set Defaults" and press "OK".
4. Press the arrow key to find "Use Factory" and press "OK"
This process would reset your printer to Factory defaults.
SOURCE: Paper won't feed correctly. Printer pulls paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
