Metabo 600242420 BHE22 7/8" SDS-plus Rotary Hammer Logo
Posted on Feb 26, 2011
Hi .. i have a this machine i have a problem when i use it works fine for 20 sec then i go to low revs on the top there a logo when lights up like it gets to hot .. then when it cools down abit it works again .... any solution ?
Kjell Bjornar Amundsen
Level 1:
Habit-Forming:
  • Contributor 57 Answers
  • Posted on Feb 27, 2011
Contributor
Level 1:
Habit-Forming:
Answers
57
Questions
0
Helped
33518
Points
93
It sounds to me as if your rotor is gone and needs to be replaced. To find out exactly, more information normally is needed. But getting hot is not good. If you also can hear increased noise and see electric sparks flying around at the commutator, accompagnied by a burnt smell, the rotor needs to be replaced. Seconday damage can also occur if you continue to run it in this state. Rotor replacement is usually a job for the professionals, but it can be done at home too. You will need the split drawings for the machine, as well as new rotor and a fresh set of carbon brushes would be well invested too. Ask you local delaer for a quote to find out if it is a economically sound replacement.
Good luck
Top Metabo Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
john h
ADMIN Andrew
ADMIN Andrew
Are you a Metabo Drill Expert? Answer questions, earn points and help others
