Plumbing Logo
Posted on Feb 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a fpsc4550A sump pump and it turns on but will not shut off the float seems to go up and down with the water level
Kirk Augustin
Level 3:
  • Master 2,020 Answers
  • Posted on Feb 26, 2011
Kirk Augustin
Master
Level 3:
Answers
2020
Questions
0
Helped
842193
Points
5973
The switch is at the top, and the float is supposed to push on the switch.
If there is anything between them, or the switch is stuck, it may not work right.
Push up on the switch manually with a piece of wood (don't like to use fingers with electricity and water), to see if you can operate it with more force.
If you can, then lift float to see if it is heavier than it should be, perhaps from leak or accumulated algae weight or something?
http://www.pumpagents.com/FlotecPumps/FPSC4550A.html
  • Dan Gibbs
    Dan Gibbs Dec 31, 2013
    There is a Cherry-style microswitch inside of the housing that is magnetically operated by the vertical float and float-rod. After years of cycling on and off, the microswitch contacts eventually wear and weld closed which cause the pump to run constantly. This has happened to me twice. The switch is a Cherry D48X 21(8)-2HP-250VAC 1HP-125VAC. The switch assembly is made to only be replaced as a full assembly, but the switch can be carefully removed from the assembly and replaced.
Top Flotec Plumbing Experts
john h
Kirk Augustin
Kirk Augustin
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
