Posted on Feb 26, 2011
Gestetner dsc338 has functional problem code - Gestetner DSc338 Copier
  • Anonymous Feb 26, 2011
    What code???
    That is very important to know for solve it
Anonymous
Level 1:
  • Contributor 16 Answers
  • Posted on Mar 07, 2011
Anonymous
Contributor
Level 1:
Answers
16
Questions
0
Helped
14176
Points
31
I`m already ask the questions please answer my question.
if you are desperate for an answer , call your local service agent for that brand and have them do a service call
we are only volunteers who may have experience on your make but other wise you will not get an answer
1helpful
Functional problems. sc500
Main motor lock, something is bound up
Gestetner Dsc445 service code error
have you checked/replaced the thermostats?
this may also be a problem with your hvt board or power supply.
Errore code sc 541
kindly call for a change of themostat
1helpful
Errore code sc 541
Your problem is in the fusing unit.Check the thermistors and thermofuses.Reset the code :
Interrupt(yellow)key - 1 0 7 -press and hold STOP/CLEAR key more 4 seconds,enter in SP mode,open the front cover,turn OFF the main switch,wait 1 minutes,close the front cover,turn ON the copier.
1helpful
When it scans document, the data can be sent to other computer in our office network except for mine. IP of computer is correctly addressed on the web monitor. Every computer has no problem but mine....
make sure the folder is shared and has wright permision enabled
and the path needs to be correct If all correct make sure the user name and password for that folder is set correctly in the hotocopier.
see if u can brouse to ur folder from the copier screen, go to scan screen press manual entry a very tiny button on the screen and see how far u get
My problem is my photocopy is not working it says functional problem within the copier turn operation switch off then on if the error appears again call services sc 560 i dont have manual what can i do
Hi the error code 560 is for the BCU which is a control board for the machine it is not getting a signal from this unit...try this ...press the yellow clear button then enter 107 then hold down the stop/cancel button till the screen changes select copier sp then 5.mode use the arrows to select 810 sc reset execute this and turn machine off .. wait a few then turn back on, if the error was a slight missread it should work away but if the error comes back you may have to remove the back panel and check the connections mayb replace the board.. good luck A.
4helpful
Gestetner 3225 error code SC544 - functional problem
SC544 indicates low fuser temperature during the warm up process. This means you have a problem with the fusing unit heating up. The fusing unit is located right where the paper exits the machine. Most common failure on these Ricoh's (Your Gestetner 3225 is made by Ricoh model aficio 250) is the fuser thermistor. This is a small electronic part that measures the temperature of the fusing roller. When they go bad they do not "see" the heat and therefor the code pops up. You are going to need to have a tech look at this for you as you will need to determine for sure which part is bad then you have to go into the service mode to reset this SC code before the machine will run.
Good Luck and Thank You for using Fixya.
Photocopier fuses hi my name is redha i would to have a definition of fuse in the photocopier in general the location and tha function ASAP Please Thanks
Redha,
Fuses are located on the power supply and some control boards.
In general fuses are used for circut protection when the load exceeds what the circut is capable of handling the fuse will blow to hopefully protect the circut and the board. This is a very broad definition.
Hope this helps
I'm getting about a 3 inch dark watermark across my pages when printing or copying. Where is that coming from? Thx Jerry lefler
Odds are you are not getting a water mark on your paper unless you are in a very wet area. You are getting fusing oil on your copies. I would look for any spilt oil aroun or under the fixing unit.
Top Gestetner Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
