DKNY -Dial Chronograph Watch for Women Logo
Posted on Feb 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get the second hand chronograph to move?
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Feb 26, 2011
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1840821
Points
13581
The upper push button starts chronometer when pushed once. Second push on the same push button stops it. Lower push button returns chrono hand to zero.
5 Related Answers
Anonymous
  • 2501 Answers
  • Posted on Jan 24, 2010
SOURCE: The chronograph second hand now resets to the 5 O-Clock position?
I have found instructions that tell you how to reset the hands but there are several buttons on your watch and to avoid confusion you really need to see a diagram.
You can do this by going to the Seiko web site (seiko.com), click on "support", then "instruction booklets".
Scroll down the next page and you will see a list of the watches made by Seiko. Select yours and download.
Go to page 16.
Anonymous
  • 2501 Answers
  • Posted on Feb 01, 2010
SOURCE: chronograph hands reset to wrong places
go to the citizen web site (citizen.com) and select "technical support" and then "setting instructions".
Enter the number off the back of your watch snd the click on "get setting instructions"
The instructions include the steps you need to take to zero the hands.
Anonymous
  • 2501 Answers
SOURCE: citizen AT03060-50E,i bobught online kind cheap
The chronograph will only run for 59 minutes 59.95 seconds.
If you do not have a set on instructions for your watch, you can find one on their web site (citizen.com)
When there, click on "technical support" and the on "setting instructions" and fill in the number off the back of your watch.
Testimonial: "thanks..it helped alot.."
Anonymous
  • 2501 Answers
  • Posted on Feb 22, 2010
SOURCE: the second hand doesn't move
I assume that you do not have any instructions for this watch.
If you enter "www.citizen-signature.com/#/settings/" you should arrive at the page for your watch.
You can download the manual or look at sections.
Bruce Robin
  • 300 Answers
  • Posted on Jun 03, 2010
SOURCE: Why isn't the second hand on my Wenger Commando SR
The large seconds hand will remain at 12 unless you press the upper right button to start it. Pres again to stop it and press the lower button to reset it. The small seconds hand that always runs is the seconds for the time. The large seconds hand is for the stopwatch function. If you like to have it running all the time just start it and leave it running - it won't harm the watch.
Second hand not moving
You shouldn't be running the chronograph timing all the time.
Jan 13, 2016 • Watches
The seconds hand on my invicta subaqua reserve does not move. It only moves when I start the chronograph. I've read the instructions time after time and can not get it to work.
The hand that moves when the chronograph is working is not a second hand. It will rest at the 12 o'clock position unless you are using the stopwatch. If your Invicta has a second hand, it is one of those small dials on the watch face.
My big second hand on my chrono watch does not move
Yes that's common, most chronograph watch's a small subdial is the times second hand. The large second hand is only for the timing function of the chronograph.
1helpful
Citizen AT03060-50E,i bobught online kind cheap than showroom so still am confused that it is original or not.. my chronograph second and minute hand stops after 1 hour,the small chronograph second hand...
2helpful
2answers
I have a police chronograph watch about a year old if that and the chronograph dials have reset themselves at random points does anyone know why and if so is there a fix? many thanks david
hi,
all you need to do is pull the centre bezel out (to where you adjust the time) and by pressing the top button the chronograph needle will move round. Once it is the correct place simply push the centre bezel back in.
Hope this helps.
Duncan
HI, i have a gucci watch YA077310 and i dont know how to set it. also the second hand does not work.
To set the time, you normally pull out the crown and rotate it. The main (large) second hand is associated with the chronograph function so is stopped at 12 when no using chronograph. There should be a little second hand in a little round area on dial that is moving.
3helpful
2answers
The second hand is not moving
make sure your mode is on time and not calender. if on calendar it sticks on the present month and does not move.
May 24, 2008 • Watches
39helpful
3answers
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
59helpful
13answers
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Top DKNY Watches Experts
ADMIN Andrew
ADMIN Andrew
colinat108
ADMIN Eric
ADMIN Eric
Are you a DKNY Watch Expert? Answer questions, earn points and help others
