Welding Tools Logo
Steve Cooke Posted on Feb 25, 2011
I have a weller EC1201A iron connected to an EC2100D base unit. It is a UK 240V model with digital temp set and display. The iron does not heat up. You can set the desired temp but the display just reads about 35C. The iron does not get warm to touch. I thought it was the iron heating element open circuit but that checks out as 15 Ohms. With the iron disconnected there is 24V AC from the base unit to the pins connecting to the heater element but with the iron connected there is 0V. There are no shorts to chassis in the iron (unless the measured 15 Ohms is too low for an element?). I have checked all 5 pins on the iron plug connections from the internals of the base unit through to the iron internals so the plug mating is fine. Unfortunately I do not have another base unit or iron to try so wonder how I can tell which of them is the faulty part?
  • Steve Cooke Feb 28, 2011
    I have found out the problem was a faulty temperature probe in the EC1201 iron itself. I found this by comparing it's cold resistance compared with an EC1201A iron. The temp probe measured 22 Ohms, mine measured 50KOhms. When I connected a 22 Ohm resistor across my iron's temp probe terminals it heated up. So I need a new temp probe, probably unobtainable here in Saudi Arabia.
omers
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 65 Answers
  • Posted on Feb 27, 2011
omers
Contributor
Level 1:
New Friend:
Night Owl:
Answers
65
Questions
0
Helped
10100
Points
89
Its my be the controler
http://cgi.ebay.com/New-weller-control-Board-EC1002-soldering-stations-/390286420305?pt=LH_DefaultDomain_0&hash=item5adee22951
good luck...
Top Weller Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
