LG LTM9000 Microwave Oven Logo
A
Anonymous Posted on Feb 24, 2011
I can reset the clock in my lg microwave oven
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 22, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
396
Points
Thank you opening the door reset the clock Thank you so much for you help
Anonymous
Level 2:
  • Expert 84 Answers
  • Posted on Feb 24, 2011
Anonymous
Expert
Level 2:
Answers
84
Questions
0
Helped
14639
Points
225
It needs contacts cleaning or touch pad replacement
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 13, 2007
SOURCE: Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Mar 18, 2008
SOURCE: Lost the users manual for
You may be able to to download a sufficiently similar model's manual here.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 01, 2008
SOURCE: Microwave stops after about 2 seconds, also have to reset the clock each time
TO mdambros
You have a bad magnetron. We see this over and over.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You'll save a lot by taking it in yourself.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
TO guest (Panasonic oven)
The door switch you suspected is bad, and it must be replaced. They normally cannot be cleaned or burnished and be reliable.
See http://www.microwavedisplay.com/doorsw.txt
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 08, 2008
SOURCE: I have lost instruction book
Normally you press one of these combinations:
CLOCK > 1 > 2 > 3 CLOCK
CLOCK > 1 > 2 > 3 START
CLEAR > CLOCK > 1 > 2 > 3 CLOCK
CLEAR > CLOCK > 1 > 2 > 3 START
Anonymous
  • 8197 Answers
  • Posted on Jan 10, 2009
SOURCE: how do I set the clock on a GE Spacemaker microwave oven?
You can get the manual here.
http://www.retrevo.com/s/GE-JVM1640SJ-Microwaves-review-manual/id/1080ci954/t/1-2/
But usually you just press the clock button to set
Good Luck and Please Rate Fixya!
Microwave oven model lmvm2085st how do you set the clock
Good afternoon Chris.
To set the clock:
  1. Push the [Clock] Button
  2. Enter the time with the keypad. For 8:37, type 8 3 7 for example.
  3. Touch [Start/Enter]
  4. Press [1] for AM, [2] for PM.
  5. Press [Start/Enter] again to finish.
You can download the manual on this page at the LG website:
http://www.lg.com/us/support-product/lg-LMVM2085ST
Hope that helps, and good luck!
Lg lmv1630bb microwave
Unless you are successful with a hard reset of the elctronics you are SOL and need to get a new control board. Check out the attached for parts Search Over 2 1 Million Appliance Parts
How do I unlock the touchpad of my Profile 2.0 Spacemaker Microwave Oven # JVM2070
calvin,
If you have access to where your microwave is plugged in, unplug it for a few minutes and then plug it back in. This will reset your contol panel. Then follow your book directions to reset the time on the clock. Hope this helps!
2helpful
I have a LG Microwave that shuts itself off before its done cooking any comments? The lights and clock are still on so its still getting power
The microwave oven has a temperature sensitive thermal fuse, if the magnetron overheats "heats food" it shuts that sector down until it cools down, "up to 30 minutes before it will reset" sometimes the thermal fuse becomes defective opening up because it has become intermittent over time. This is a tricky problem to diagnose and should be checked by somebody who is familiar with these types of devices.
3helpful
Whirpool microwave resetting clock
Whirlpool Microwave X2-30ES
I was pressing one too many buttons.
Press Clock, then Stop, press in the 24 hour time digits, then press Clock again.
My LG LMV1630ST has an issue with the clock. The
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Is it a US model (made for 60HZ power) being used overseas
(50HZ power)?
* * * * * NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more FREE help & do-it-yourself advice.
William E. Miller
prototech@usa.net
6helpful
2answers
I cannot set the clock on my LG MS1949G Micro wave
After spending 25 minutes on hold while LG try to find out how their own product sets the clock, I now know that the LG MS1949G Microwave open does NOT have the ability to set a clock that shows the time of day.
Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
LG microwave no longer heats!
It sounds as though you may have run the microwave while empty, which can damage the magnetron.
Not that I'm optimistic, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise it likely needs a new magnetron.
Top LG Microwave Ovens Experts
Paul Carew
vince
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
