Acer X203H bd Monitor Logo
Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the exact resolution of the Acer X203H monitor
Anonymous
Level 2:
Sergeant:
  • Expert 158 Answers
  • Posted on Feb 23, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
158
Questions
0
Helped
45838
Points
505
1helpful
Connect my Acer monitor to my digital cable box.
Not sure what your cable box outputs but connect your cable box to a tv and try changing the resolution of your cable box to 1600x900 or less if there is such a setting; the monitor will not display resolutions higher than 1600x900
I have windows xp and an Acer x203h monitor which is 1600 x 900 - xp does not support the vista version of the x203h driver - where can I get a driver that will work with this monitor size and xp, I'm not...
The resolution depends on the video card capability. If you cannot reach 1600x900 I would suspect your video card is the limitation not the monitor.
How to shrink screen size to fit larger monitor?
You should set the PC resolution to 1600 x 900 @60Hz for the native resolution of this monitor.
1helpful
I have a new Acer X203H 20" wide computer monitor. All of my photos are streched wide, and everyone looks fat. Can I adjust this ?
You need to set the PC video resolution to 1600 x 900 for proper 16:9 wide screen format. But if your pictures that you taken with your camera were not 16:9, IE 4 X 5 then it will be stretched side way to fill the screen.
How do I get a normal image on an Acer X203H monitor?
right click on your desktop and select "properties" (xp)  or "personalization" (vista/7).  In xp, select the "settings" tab, and in vista/7, select "display settings". then adjust your screen resolution to a wider aspect ratio to compensate for the wide screen.
Can't change resolution on an acer x203h video monitor
The resolution is changed on the PC and not the monitor. Right click on the desktop and select Properties->Settings->Screen Resolution. Here you will get a slider showing Minimum to Maximum resolution that your monitor is capable of taking. Start sliding the indicator one notch at a time and click OK when satisfied. You will be given an opportunity to revert back to the original one should you want to. Go ahead and change to a more likeable one.
3helpful
Files appear too large on Acer monitor
If you just want to change the size of the font of the web pages you are visiting...all you have to do is hold down the CTRL key while tapping the + or the - key the will increase and decrease the font size.
To check the resolution just right click in an empty area of the desktop and scroll down to properties....you can play around with the resolution there....don't worry, you get 15 seconds to decide if you like the setting before it reverts back to the previous setting.
1helpful
2answers
All icons and other images are undersized. Acer Model #X203H
Adjust the screen resolution a little lower and the icons will be a little larger.
Try a screen resolution of 1028 X 768
1helpful
2answers
Acer x203h only yields 720x480 resolution with Panasonic DVD player via HDMI output. Pana will not allow setting to output higher than 480p attached to this monitor. With computer, can adjust to full res...
The fact that other devices can go higher than the resolution provided by the panasonic dvd player is a strong indication that this is not a screen issue but one with your dvd player and you should consult the manual or web site for your particular model to find out what its limitations are
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
