Consider getting a card reader instead.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: Where can I buy replacement parts for Casio EXILIM ZOOM EX-Z60
I have those parts available at gerald.ray@aa-ark.com. Thanks
SOURCE: Lost cable to connect Casio exilim EX-Z77 to
you need a usb-mini b cable can get it off ebay real cheap...
http://cgi.ebay.com/USB-A-to-Mini-B-5-Pin-Data-Cable-Adapter-Male-M-MP3-DC_W0QQitemZ250447346226QQcmdZViewItemQQptZPCA_Cables_Adapters?hash=item3a4fd33a32&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1205|293%3A1|294%3A50
SOURCE: I need a camera cable (USB) for my casio EX-Z9
You can get the correct lead from almost any large computer or photographic store, it does not have to be the official Casio item.
The lead needs to be a standard USB socket at one end (USB type A) and the other end is a micro USB (micro USB type B). This is by far the most common type for many cameras and phones now so shouldn't be expensive or difficult to find.
Alternatively, ditch the cable altogether and use an external card reader. Removing your memory card and putting it into an external reader to transfer images is usually much faster, especially if you also avoid using the clunky and non-essential software which most cameras are supplied with.
I hope that you've found my reply to be of use and ask in return only that you rate my answer.
Testimonial: "Great help. Thanks."
SOURCE: Casio Exslim EX-Z33: Lens Error Message; Lens stuck
The camera might not of had been dropped or abused at that moment, but it sounds like one of your ribbons is not full connected to its port due to a previous unnoticeable drop or mishandling. In other words, if you are savvy enough to open the camera, remove the ribbons (2 of them, found on the front side of the camera coming from the lens) and re-insert them into their ports. I have only needed to do this once on this particular camera, but at least 30 times on the Exilim line of Casio cameras. Hope this helps.
I’m happy to assist further over the phone at https://www.6ya.com/expert/pedro_4520403b21ed459a
