Samsung Galaxy S GTI9000 Smartphone Logo
Anonymous Posted on Feb 14, 2011
Where the draft save - Samsung Galaxy S GTI9000 Smartphone
Anonymous
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Mar 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
12538
Points
91
If you're talking about the message draft, it is inside the message thread. in the box where you type your text. if its not there, then the draft is already been deleted. cheers.
  • tuckerlaura Jul 11, 2011
    Is it possible to save more than one draft at a time on the Galaxy S2? Just got one and can't figure out how to do this at all. It seems to automatically delete one draft if you start another one.
  • Anonymous Jul 12, 2011
    I don't think its possible. But one thing that i can suggest is that you write your message in (the application) Memo. You can write it and save it, then you can press the menu button (with the message on Memo opened) to bring up the options, and press 'send via' -> 'Messaging' when you want to send it. Cheers mate.
1helpful
How do I make a draft sms message and save it. How do I then send it to someone?
To make draft messages on your phone..First go to message menu create message..Type message you want,after typing click OK button of yuor phone there are options that says save messages..To access that message ,go to the message menu choose draft or save message,select the message you want to send click OK and select edit then Click OK button of your phone select SEND then choose the number in your phonebook..Hope this helps..
Jun 20, 2011 • Cell Phones
8helpful
3answers
I have a samsung tablet and can't find the drafts folder. On the net it says to right click the inbox folder, how do you right click, there is no mouse
I'm having the same problem - I've added an account using the app (not gmail.. it's actually hotmail as one can add any email account) and when I saved the message I now see there is no draft folder to access that I can see.I also went to hotmail's web email and can't find the saved email there either. I've searched the entire tablet but cant find where it might have been saved to.
Samsung sgh-g600 is saving to draft how do i stop it saving to draft
You can stop it from saving into draft by un-checking the option for that in the message settings. Also if you do not send the text and just press the Back key, it would automatically save the text in drafts so you may use it in future. I hope this helps.
I wrote the long message and wanted to send it later. Later I could not find my written mesage to send email. I did not find outbox nor Draft symbol in the screen. How should I get my written message back
It should have been auto saved in the drafts folder. If it is not in the drafts folder, It is most likely gone. Outlook uses word as an editor and word will auto save every so often. It will place an .asd file in your temp folder. Your temp folder location will depend on your Windows version. I'm not talking about windows/temp. It is most likely under Documents and Settings\(your user name)\Local Settings\temp. The Local Settings folder is hidden so you must set your settings so that you can view hidden files and folders.
I suggest either making sure you save your message to draft every so often as you write it .. OR a better solution is to use Word. Word will auto save every so often and the document can be recovered.
How auto save works
How to view your Local Settings files/folders
hopefully you can find the saved file there.
1helpful
How many listings can i save for completion at a late time
with regard to saving drafts, you can only save one draft at a time. if you will save another one, your old draft will be deleted by the system. you will need to list the item so that you can create a new draft.
I have a saved draft that I want to send . The original email address wasn't recognised.
nannydiz1- If you forward a saved draft and attempt the new email in the To box, you should be able to send from your draft. This is not a problem with your laptop it sounds like and Email question. Correct?
Save as draft
There are several reasons as to why a message might not have been delivered.In such a case the message is not lost...it simply is not sent and then is saved as a draft on your phone .You can choose to send it later.Look for it in Drafts in your message applcation.
When I go to save an email as a draft it says it
Firstly compose your messages and send directly to your draft. before you do that ensure that you are connected to your broadband properly, then send anything you wish to send
Sep 21, 2009 • Yahoo Mail
Cant save new draft emails in my draft box
what error does it give. i also use thunderbird when ever i compose email and click on save it is save.
Jan 07, 2009 • Yahoo Mail
Top Samsung Cell Phones Experts
Sudeep Chatterjee
Sudeep Chatterjee
vince
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
