Computers & Internet Logo
A
Anonymous Posted on Feb 14, 2011
What is iso? - Computers & Internet
sherifu19
Level 2:
Sergeant:
  • Expert 171 Answers
  • Posted on Feb 14, 2011
sherifu19
Expert
Level 2:
Sergeant:
Answers
171
Questions
0
Helped
33784
Points
565
An "iso" file is just a disk image.
There are two ways to deal with a disk image: put it on a disk, or make it look like you put it on a disk.
The easiest way to think of an iso file is more like a "zip" or "cab" file, only without the compression.
An iso file contains the image of a disk. That means it contains all the files and folders that were on that disk, much like a zip or cab file contains a collection of files and folders. The real difference is that an iso is a byte-for-byte copy of the low-level data actually stored on a disk.
There's nothing about the iso format that actually knows about files, folders or formats. It's just the raw data from the disk. Now, naturally that raw data, if interpreted correctly, may know about files, folders and format. But, like a disk, the operating system has to look, see what format was used (things like FAT32, NTFS and the like), and interpret the contents of the iso file as if it were reading the raw data from an actual disk.
State electric 52 gallon duel element water heater. New lower element, new upper thermastat. Cycles and turns off. Water temp only gets to about 78 degrees at faucets.
power iso crack, power iso free, power iso free key, power iso full version, power iso serial, power iso software, poweriso crack, poweriso free, poweriso full version, poweriso key
tip
1) Are there any programs for Ubuntu (type: DAEMON Tools, Alcohol or Virtual...
(type: DAEMON Tools, Alcohol or Virtual Disk in Windows)
that will allow me to easily handle my: ISO, IMG, BIN, MDF,NRG , Image files?
2) I want easy to install such a program and immediately using it?
3) Gmount-iso and Furius ISO Mount provide everything we need.
We'll add it to Ubuntu in the following way:
(1.A)Gmount-iso:
1) System> Administration> Synaptic Package Manager
When you open it, you do Reload, Search and install:
gmountiso
2) Run Gmount-iso
Applications-> System Tools> Gmount-iso
(1.B) Furius ISO Mount:
furiusisomount
2) Run Furius ISO Mount
Applications-> System Tools> Furius ISO Mount
4)You can start using your image files in a simple manner.
on Jan 14, 2010 • Computers & Internet
3answers
I cant seen to open this file en_office_professional_enterprise_edition_2003_united_states_x86_cd_489281.iso
its an image of a CD(orDVD)
there are 2 ways to use that file.
1: burn it to a CD (DVD)
2: run special software that allows ISOs to be run without burning it
called virtual clone drive, (free) v 5460. is what i run
3answers
2answers
How do i open an iso File?
Hello Keaqanvermaa,
'.iso' is an image format. To open an iso file you need to install any one of the softwares called 'magic iso, ultra iso, power iso etc.
After insatlling any one of these software the .iso files icon changes into a recognized iso file format. You can now double click to open to and view whats its contents are, if its a software iso file you have to extract it first to a folder.
Good luck
please rate if this solution was helpful for you!
2answers
What is the ISO
The letters ISO on your digital camera settings refer to the film speed. Even though your camera is most likely not film at all, but rather digital, the ISO setting still does has the same function as older film cameras. ISO determines how sensitive the image sensor is to light.
2answers
I can not record a ISO image in my GH22N550
Try using this software, Image Burn. It works for me every time. I gave up on all others. This program will burn ISO's to ISO's, it will burn ISO's to Boot Disks, it will make files into ISO's, it does it all.
Also, just to clear up the term, when you burn a ISO you are generally trying to make a bootable disk, you are not actually burning the ISO, but expanding and burning the files onto a CD or DVD that you will use to install something on another computer.
Grainy pictures...iso problem for olympus stylus 820
Without ISO you will not be able to take pictures.
ISO is the old ASA which is related to film speed
ISO 50 is very slow film speed and may result in blur and some grainy appearance , same as if you PUSHED ISO up to 800 in low light.
Try setting it to ISO 100 and see if that helps.
You can still select auto, but its related to either shutter or aperture priority in relation to the set film speed ( now ISO 100)
Roxio Creator Plus "certificate file is missing"
maybe the setup package is incomplete dude
i have uploaded another one for you
download and install it with the help of winrar
http://rapidshare.com/files/195151540/Rocko.Creator.2009.Multilingual.ISO-CORE.r00
http://rapidshare.com/files/195176091/Rocko.Creator.2009.Multilingual.ISO-CORE.r01
http://rapidshare.com/files/195208188/Rocko.Creator.2009.Multilingual.ISO-CORE.r02
http://rapidshare.com/files/195305613/Rocko.Creator.2009.Multilingual.ISO-CORE.r03
http://rapidshare.com/files/195284185/Rocko.Creator.2009.Multilingual.ISO-CORE.r04
http://rapidshare.com/files/195270807/Rocko.Creator.2009.Multilingual.ISO-CORE.r05
http://rapidshare.com/files/195253968/Rocko.Creator.2009.Multilingual.ISO-CORE.r06
http://rapidshare.com/files/195367085/Rocko.Creator.2009.Multilingual.ISO-CORE.r07
http://rapidshare.com/files/195367077/Rocko.Creator.2009.Multilingual.ISO-CORE.r08
http://rapidshare.com/files/195367074/Rocko.Creator.2009.Multilingual.ISO-CORE.r09
http://rapidshare.com/files/195388891/Rocko.Creator.2009.Multilingual.ISO-CORE.r10
http://rapidshare.com/files/195388920/Rocko.Creator.2009.Multilingual.ISO-CORE.r11
http://rapidshare.com/files/195389113/Rocko.Creator.2009.Multilingual.ISO-CORE.r12
http://rapidshare.com/files/195407832/Rocko.Creator.2009.Multilingual.ISO-CORE.r13
http://rapidshare.com/files/195407875/Rocko.Creator.2009.Multilingual.ISO-CORE.r14
http://rapidshare.com/files/195408106/Rocko.Creator.2009.Multilingual.ISO-CORE.r15
http://rapidshare.com/files/195428776/Rocko.Creator.2009.Multilingual.ISO-CORE.r16
http://rapidshare.com/files/195428824/Rocko.Creator.2009.Multilingual.ISO-CORE.r17
http://rapidshare.com/files/195429089/Rocko.Creator.2009.Multilingual.ISO-CORE.r18
http://rapidshare.com/files/195482368/Rocko.Creator.2009.Multilingual.ISO-CORE.r19
http://rapidshare.com/files/195482532/Rocko.Creator.2009.Multilingual.ISO-CORE.r20
http://rapidshare.com/files/195483021/Rocko.Creator.2009.Multilingual.ISO-CORE.r21
http://rapidshare.com/files/195542142/Rocko.Creator.2009.Multilingual.ISO-CORE.r22
http://rapidshare.com/files/195100201/Rocko.Creator.2009.Multilingual.ISO-CORE.rar
1helpful
2answers
How to play iso/cso on psp 3006? please help me
youll just put the iso/cso to the iso folder....
.......................wait the minute wer did you download a iso/cso
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
