Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
Posted on Jul 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have an Ariston AVTL 110 Top loading washing machine. We had it for 5+ years with heavy usage. Suddenly, it stopped working. We can turn on the programing, it appears the program starts just for a second, and stops. My guess is that the "electrical valves" which are supposed to open, are not opening. We are in france and I have not seen any trouble shooting guides other than, "is it plugged in".
rpar
Level 3:
Master:
  • Master 415 Answers
  • Posted on Jul 14, 2017
rpar
Master
Level 3:
Master:
Answers
415
Questions
0
Helped
105712
Points
1153
Have you tried unplugging it for 5 mins. to reset it then re plug to see if that helps
Marvin
Level 3:
Top Expert:
  • Ariston Tech... Master 85,242 Answers
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29677566
Points
266298
Sounds like the washer control panel has failed.
4 Related Answers
Anonymous
  • 183 Answers
  • Posted on Jul 29, 2007
SOURCE: Flashing Lights on Ariston A1636 & Won't progress to rinse either
Suggest checking for a faulty heater. Regards Engineer
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 13, 2009
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Anonymous
  • Posted on Jan 23, 2010
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Anonymous
  • 6277 Answers
  • Posted on Mar 14, 2011
SOURCE: Hi,my ariston AVTL 104,will not
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Top Ariston Technologies Washing Machines Experts
vince
ADMIN Andrew
ADMIN Andrew
Curt mueller
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
