Kenmore HE2 Plus Front Load Washer Logo
Posted on Feb 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code f33 - Kenmore HE2 Plus Front Load Washer
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Mar 04, 2011
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5221074
Points
35546
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
CLICK HERE
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa*&^%
Flashing F33 error code thermador double oven
either a bad oven sensor or a bad power relay board.
Everytime i try to run a load of wash i get a F33 error - what can i do?
Please clarify the Model and Make of your Washer.
The F33 error for Whirlpool: The "F33" error code means that the washer has encountered a system error with the pump drive. The parts should be working fine; it is just the connection that caused the problem.
Check connectors on central control board.
F33 error code
CLICK HERE
Thanks for using FixYa&^&^
2helpful
Washer codes F01/F33, have cleaned the pump and
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
2helpful
I have a Kenmore He2plus washer that gives me an error of F33
"F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch. The flow meter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Thank you !!
2answers
Error code f33 on an he4t
4helpful
F33 error code. drum begins to rotate and then
Kenmore elite he3t model 4596640 year 2005 f33 code
1helpful
Error code f33
2helpful
2answers
F33 error code
F33 System leak If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
1. Check for crack or holes in the washer tub and pressure switch hose.
2. Replace components if necessary.
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
