Canon Pixma MP500 All-In-One InkJet Printer Logo
Posted on Feb 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 6a00 - Canon Pixma MP500 All-In-One InkJet Printer
Anonymous
Level 3:
  • Master 2,296 Answers
  • Posted on Feb 17, 2011
Anonymous
Master
Level 3:
Answers
2296
Questions
0
Helped
846178
Points
6040
Error code 6A00 means an error occurred in the AP motor during purging operation. You will need to replace the sheet feed unit (part no. QM2-2916), logic board assy (part no.QM2-3078), purge unit (part no. QM2-2925).
1helpful
6A00 error code
6A00 is a problem with the sheet feed unit. I would get in touch with Canon, to hopefully get it repaired. Not much you can do yourself sadly.
5helpful
Error code 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All The Best: Pineworks
ERROR CODE 6A00
Effective Solutions to Troubleshoot Canon Printer Error Code 6A00: Cartridge faults are not always easy to deal with.
Solution 1: Check Print Head Carriage
  • Make sure whether the printhead carriage is moving back and forth properly or not.
Solution 2: Check the Purge Unit
  • If you have just moved the printhead assembly, the purge unit error will still be there.
Solution 3: Reseat the Ink Pads
  • Press down the ink pads down in the purge unit.
To know more: Canon Printer Error Code 6A00
1helpful
2answers
Canon Mp780 error code 6A00
6A00 is not a jam error, it is an error of the purge assembly not cycling properly. Many times a paper scrap jammed in the capping assembly or the squeegee assembly caught on the filter assembly. Usually worn out gears and dried ink so that replacement of the purge assembly is the best fix.
1helpful
Service error 5c10, error code 6a00 wored
6A00 is the error when the purge assembly is broken or jammed. You need a shop to install a new one since the entire print engine has to come out to replace it.
MX850 ERROR CODE 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
8helpful
Canon pixma mp800 error code 6A00
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
1helpful
6A00 error
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
2helpful
Error code 6A00
Error Code 6A00 is a problem with the sheet feed unit. You cannot fix it by yourself because you do not have the tools to fix the printer.
You go to a Canons Support Page and ask for a replacement if it is still under warranty or you replace the printer with a new one.
5answers
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
