Cisco Aironet 1142 (AIR-AP1142N-A-K9) Pre-802.11n  Wireless Access Point Logo
Posted on Feb 09, 2011
I need to factory reset my AP1142N-A-K9 - Cisco Aironet 1142 (AIR-AP1142N-A-K9) Pre-802.11n Wireless Access Point
Why my K9 alarm doesn't lock my car doors but can unlock them?
Where are you seeing SPAM? The Admins and IT Teams remove every bit of spam we can find. We also use some highly advanced solutions now. You may be seeing historical spam, but shouldn't be seeing anything recent. Please report any spam.
All question need full 'make model (what it is)' for an aftermarket alarm, and 'year make model' for a factory alarm. A K9 is a dog?
Generic solutions only. You have a lock module issue.
https://www.google.com/search?q=K9+alarm+doesn%27t+lock+my+car+doors+but+can+unlock+them
Or an auto electrician with a professional grade scan scan tool computer can diagnose all electrical issues in about 30 minutes, all the modules and all the sensors IF it is a factory item. Note that an auto electrician is NOT a mechanic If it is aftermarket you need an Alarm Installer.
https://www.google.com/search?q=auto+electrician+near+me
I forgot my password to my k9 account and since I blocked the web 24 hours I don't have an option for them to email me a new password- what can I do to get rid of k9?
Hello, Dear,
here are some steps , you can check it out :
If you've forgotten your K9 Web Protection password and can't reset it due to web restrictions, you have a few options to remove or disable the software. Here are some potential solutions:
1. **Uninstalling K9 in Safe Mode**:
- Restart your computer and boot into Safe Mode. This can usually be done by pressing `F8` (or `Shift + F8` on some systems) during startup.
- Once in Safe Mode, try to uninstall K9 Web Protection from the Control Panel.
- If prompted for a password, this method might not work unless you recall the correct password or use a method to bypass it.
2. **Using System Restore**:
- Use the System Restore feature to revert your computer to a previous state before K9 was installed or before the password was set.
- This won't always work if K9 was installed a long time ago, but it's worth trying if the installation is recent.
3. **Editing the Registry**:
- This is a more advanced option and should be used with caution.
- Open the Registry Editor by typing `regedit` in the Run dialog (`Windows + R`).
- Navigate to `HKEY_LOCAL_MACHINE\SOFTWARE\Blue Coat Systems\K9 Web Protection`.
- Delete the K9 Web Protection folder from the registry.
- Reboot your computer, and K9 should be disabled or uninstalled.
4. **Using K9's Emergency Password Reset Tool**:
- If you have access to another computer, you can visit the K9 Web Protection support website and request an emergency password reset tool.
- This tool can be downloaded and used to reset your K9 password. However, this may still require some form of web access.
5. **Contact K9 Support**:
- If none of the above options work, try contacting K9 Web Protection support. Explain the situation and ask for assistance in recovering your account or removing the software.
Please note that if K9 Web Protection was installed by an administrator or for a specific reason (such as parental controls), it's important to get permission before attempting to remove or disable it.
Does CISCO1921/K9 support VPN?
It depends, if you want to setup IPSec VPN, you will need to add SL-19-SEC-K9 or L-SL-19-SEC-K9 license; if you want to use SSL VPN, you will need to buy one of these lincense: FL-SSLVPN10-K9(10 Clientless Users), FL-SSLVPN25-K9(25 Clientless Users), or FL-SSLVPN100-K9(100 Clientless Users), the exact number is up to your SSL users quantity. SL 19 SEC K9 Price Buy Cisco 1900 Series Routers License SL 19 SEC K9...
Factory code
if the phone is not dead the factory reset code is *#8929#
If the phone is dead, you have to use alternative compter softwares eg. Volcano Tool v2.3.9
May 16, 2014 • Karbonn K9
2helpful
How to reset 9971 cisco phone to factory default
You can do that by pressing the Applications button on the phone and choosing Administrator Settings. From the Administrator Settings menu, unlock phone options, then choose Reset Settings > All Settings.
I hope this helped you.
Hello all, i need to reset password on Cisco wireless LAN controller NME-AIR-WLC8-K9 module installed on router 3800 thanks a lot
Press a restart button at the back of your router, and hold it like that for 20 seconds.
That will reset all your settings!
Good luck. I hope this will help You!
2helpful
2answers
How to reset to factory default?
Hi nbergma,
To Factory reset your router you need to locate the Reset Button at the back of the router. The Reset Button is the small hole at the back and you need a Pen or a Paperclip to press it. Press and hold the reset button for 10-15 seconds. Make sure that the router is on when you reset it.
Thanks for using Fixya.
Reset my Cisco AIR-AP1242AG-N-K9 but still can't access the control panel using a console calbe and laptop. Using Cisco Cisco as user name and password. Note when typing the password nothing appears in...
Hmmm..., I assume you are using Windows..... Try just going to the Network, see if you router shows up if so.... Click on it... It should ask for a pin type in the pin that usually can be found on the bottom of your router... If not reset to factory defaults and in your broswer type in your IP address, do not use autoconfiguration.... On all Linksys routers the default username is admin (with the password left empty) from there you can set your password and configure your router for use.... Hope this helps ;)
How to reset c2106 to factory defaults?
do you have a little button behind it ?if you do tap it for 20 seconds.
2answers
Shutdown or find the admin password for k9 blue coat
You will have to remove k9 or wipe and reload the OS. The issue is caused by the k9 software.
If you bought the machine with k9 preloaded, then you will need to wipe and reload your OS and drivers, or call k9 for removal.
If it was installed for you by an administrator, (your computer guru), you had best speak with him/her before taking any action. Administrators often have records of these things, and they can assist you.
If you are a parent and you installed this to protect your children, but you forgot the password, then you may need to call k9 and have someone assist you. there is likely a "master" password or a reset code they can give to allow you to reset and reapply your settings.
If you are a child trying to get into adult websites, and your parents installed k9 to stop you, then I suggest you grow up, get a job, buy your own computer, and do as you will with it. After you drop $700 to $900 of your own money into it, then you may visit anyplace you desire, and infest it with junk. Once it is no longer useful, you may begin to appreciate why someone tried to install security on it. Once your investment becomes a blinking bleeping heap of slow uselessness, you might understand why your parents installed k9.
Good luck.
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Kirk Augustin
Kirk Augustin
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
