Tomtom Xl 335 S GPS Receiver Logo
Posted on Feb 06, 2011
Problem with map You cannot use this map on this device: North_America_P-261 I have a Tom Tom XL340 I purchased it in Australia & it was working fine there, then moved to Canada, managed to finally get the maps to download, after many errors & now I have the above problem when I try to change maps from Australia to North America.
5 Related Answers
Anonymous
  • 178 Answers
  • Posted on Feb 20, 2008
SOURCE: ACCESSING A NEW MAP
SOUNDS LIKE YOU DOWNLOADED IT TO TOM TOM HOME AND NOT TOM TOM ITSELF. OPEN UP TOM TOM HOME AND LOCATE THE US MAPS THEN THERE SOULD BE A OPTION TO TRANSFER MAP TO TOM TOM.
I HAVE ALSO 910 TOM TOM AND A PRO AT TOM TOM DEVICES
LET ME KNOW
Anonymous
  • 158 Answers
  • Posted on Nov 11, 2008
SOURCE: Tom Tom one just comes on and then says that there is no GPS devi
It "might" be that your tomtom has lost its position due to you moving countries. the TomTom stores its last position so each time you switch it off then on again it can find the satellites it had before quickly. Because you have moved a long way ( on the aeroplane ) the TomTom now thinks you are still in America so it's looking for the satelittes over America rather than over the UK.
I would try this :
  • Press the reset switch through the hole at base of tomtom ( 1 quick press is all you need , dont press too hard , you should feel the switch click as its a tactile switch )
  • The TomTom has now had a hard reset
  • Go outside in a location where you have a clear view to the south . ( preferably a clear view from east through south and to the west )
  • Switch the tomtom ON
  • Make sure the tomtom has a clear view of the sky and the top of the tomtom ( its antenna is in the top ) is unobstructed.
  • Tap the screen just above right bottom ( where you see the signal bars )
  • The next screen shows the battery state and some bars on right side
  • Tap the bars
  • You should now have a bigger screen with bigger bars
  • The bars are each channel your tomtom can receive satelittes on
  • Wait about 3 to 4 minutes and see if any of the bars are GREY
  • Grey bars shows you are receiving satelittes ( but signal is week )
  • Blue bars show good strong signals are being received
  • It may take a few minutes to lock on ( fingers crossed )
  • If it does have a lock ( at least 3 blue bars ) your tomtom will remember and store these satelittes so next time you switch on it will go straight to them quickly and lock on .
  • Your problem will be sorted.
if you dont get any bars at all then it's likely your tomtom has become faulty in the receiver or antenna section and will need proffesional repair . Rare but It is also possibly a files / data fault on your SD card . In this case if you made a backup of the card , you will need to revert to that and reinstall the files to the SD card.
GOOD LUCK
Anonymous
  • 949 Answers
  • Posted on Mar 27, 2009
SOURCE: Not enough space for maps?
The garmin does not have any space on it for maps,any additional maps are stored on a memory
card. I don't see where garmin says the size limit of the card but in most cases unless it says
SDHC memory card,then the max is a 2g sd card, I think the models 500 and over can use over a 2g card.,
Anonymous
  • 3 Answers
  • Posted on Apr 17, 2009
SOURCE: Call 1-8O5-225-669O GPS/GARMIN Update-Install-Download-Fix We are 24 Hour Available Call Now For Help
I just got off the phone with tech support. They have a very complicated fix that involves remote accessing into your computer and editing files, etc. They said it would take over an hour and a half, I declined. The problem apparently is that the nuvi 200/205 can't support canada, but the maps contain canada = problem. and btw, i downloaded "City Navigator Lower 49 States+PR NT 2010.10, Deluxe, Apr 09" and got the same problem. this filename ends in a "B", apparently that's the "fixed one" but acc tech support it's only fixed in the sense that they can waste over an hr w' u fixing it, whereas the older files are unfixable.
I'm just gonna wait til they really fix it and upload those files.
Hope that helps.
Anonymous
  • 36 Answers
  • Posted on Aug 02, 2009
SOURCE: unable to find/use Canada Map on TomTom ONE 125
Nowadays TomTom provides all of its maps through TomTom Home desktop software.
You have to download and install that, and then connect you TomTom to your computer. Then you can browse through and purchase any of the available maps through the software providing you have room on your TomTom to hold the map.
Top Tomtom GPS Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Frank Fernandez
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
