NorStar Jazz Plus 4400 Corded Phone Logo
Anonymous Posted on Feb 02, 2011
How do i reprogram my speeddial numbers on jazz 4400?
  • Anonymous Feb 03, 2011
    The buttons on my phone are, top row are mute,hot line,shift
    second row are redial,flash,save..
    Your solution did not relate to the above buttons
  • Anonymous Feb 05, 2011
    Instructions you sent do not fit buttons on my phone, which are as follows,Mute, Hotline-911-red button. Shift, Redial, Flash, Save. My phone does not have a display window, or a hold button.
    Please be more specific.
J. Van
Level 3:
President:
  • Master 1,738 Answers
  • Posted on Feb 05, 2011
J. Van
Master
Level 3:
President:
Answers
1738
Questions
Helped
633654
Points
5775
Although I've been unable to locate a User Manual specific to your phone, the following information pertains to programming most all NorStar phones:
To Program Buttons On Your Phone:
For External Numbers:
1. Press the Feature button, then * 1
2. Push the button you want to program
3. Display will read "Program and OK"
4. Enter the telephone number, then press the OK softkeyFor Internal Numbers (Extensions.:
1. Press the Feature button, then * 2
3. Display will read "Intercom #:__"
4. Enter the extension number
For Feature Codes:
1. Press the Feature button, then * 3
3. Press the Feature button then enter the Feature Code
To Change the Contrast of the Display:
1. Dial the Feature button, then * 7
2. Press the number keys 1 - 9 to your desired brightness level
3. Press the OK softkey
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 - 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.)
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94. that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
Additional information about NorStar phones can be found by clicking here:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
Anonymous
Level 3:
Genius:
  • Master 1,456 Answers
  • Posted on Feb 04, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1456
Questions
0
Helped
482883
Points
4013
Hello
please follow these steps to reproram speed dials
1. Press FEATURE * * 2 6 6 3 4 4
2. Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
3. Press: NEXT Display will read: "B. General Admin"
4. Press: SHOW Display will read: "1. Sys speed dial"
5. Press: SHOW Display will read: "Speed Dial #:___" HINT: Begin your system Speed Dials with "01"
6. Enter: 01 or 02 or 03 etc... Display will read: "Speed dial #:01"
7. Press: SHOW Display will read: "No number stored"
8. Press the "CHANGE" softkey. Display will read: "#01:
9. Enter the Speed Dial number
10. Press the "OK" softkey.
11. Press: NEXT Display will read: "Use prime line"
12. Press: NEXT Display will read: "Display digits:Y"
13. Press: NEXT Display will read: "Bypass restr'n:N"
14. Press: NEXT Speed dial 01 has now been programmed:
To program another Speed Dial Number, repeat steps 6 thru 14.
Anonymous
Level 3:
President:
  • Master 3,278 Answers
  • Posted on Feb 02, 2011
Anonymous
Master
Level 3:
President:
Answers
3278
Questions
0
Helped
797091
Points
9440
Hello.
From NorStar Support:
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
    Sorry for not getting back to you sooner.
    Try: (Press one of the ten buttons on the side), then dial the number, then press the Save button. Repeat for each phone number for each of the ten buttons on the side.
    If that doesn't work, try: Save, dial the number, then press one of the ten buttons on the side.
    Hello, again. My suggestions didn't help ???
Top NorStar Lands Phones Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
