Datamax H-Class H-4212 Printer Logo
Posted on Feb 01, 2011
What is a top of form fault error? - Datamax H-Class H-4212 Printer
2 Related Answers
Anonymous
  • 97 Answers
  • Posted on May 14, 2010
SOURCE: Top of Form Fault error
It means that the printer did not get a good calibration on the label. First make sure the label sensor is in the proper position. Look at the green bar that the label passes underneath and make sure that the white line (the sensor) is positioned over the label. Then calibrate by pressing and holding the FEED key for about 5 seconds until the labels start to feed. After a few labels feed out, the printer should now have a good read on the size of the label and be ready to go.
Hope that Helps !
Anonymous
  • 87 Answers
  • Posted on Nov 22, 2008
SOURCE: top of form fault
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Hope this helps you.
Top Datamax Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
